What is your IPD?
67, measured using mirror & ruler
59.5 - Optometrist measured
66, measured in mirror with ruler.
IPD alternative meaning :
-International Paiement Data
Sry had to :joy:
55, credit card in picture
63,5 - 64 is mine. :sunglasses:
Hi - Mine is 60mm
~Lori
I think is 62 with ruler
67 measured by optometrist
My IPD seems to be very small - I have the sharpest image @60,5mm in the vive. Cant reduce that IPD, so I dont know if its smaller
64 here as measure by spec-savers.
62-63 mm, from the optician measured.
In my case, i find the Gear vr IPD which is 62 mm ideal for me, no overlapping, no line in the middle of sight, better than the rift adjustment…
I use gear vr to and its perfect for me. I dont se nothing. For example the rift i see a vertical black line in midle and tried everything even change the ipd and the vertical line dont disappear. Lenovo explorer and vive works fine to. I am afraid pimax has this problem . Anyone knows why this hapens?
A little question: Probably the lenses are moving not straight horizontally, more bent to the position of the displays. As a result the ipd will change with the distance between eyes and lenses too. The nearer the face/eyes to the lenses the wider the position of the lenses to each others (=ipd setting). Difficult to explain.
In all other headsets the ipd isnt changing if you are nearer/wider to the lenses because the ipd is straight horizontally.
Mine is 68 from the optician
67-68 measured with ruler.
66 measured by my optometrist.
72mm , measured by an optician.
63.0 - 63.4 from 2 different eye checks at opticians
my ipd is 62,5
