Hi Enthusiasts,
We would like to know your IPD figure to make sure the range we covered is large enough for you.
EDIT
Several simple ways to choose from:
How to Measure Your IPD | Doc-Ok.org thanks to doc_ok
- Use a credit card sized plastic.
OptiContacts.com -- How to read your contacts
- Go to an optician
Mines 65 professionally measured.
Also I wouldn’t give my CC and CVV code to anything except payment systems on the internet.
64mm, I use mirror and ruler to measure this, I do not want to upload personal photo and card info.
Mine is 64, right from the Optometrist.
65.0mm
maybe 1 or 2 mm error
65, professionally measured. Sometimes I turn it upwards of 72 though. I don’t know why, some days it just looks better that way.
69,5 professionally measured last week by optician.
Call me old-school, but I would strongly recommend you not to upload a photo of your credit card to that site
Sjef
8
70.5, professionally measured
Sjef
9
Agreed, as the back of the CC not only shows the CC number but also the 3 digit safety code
About 67, unprofessionally measured.
Sjef
11
Btw @deletedpimaxrep1 you’d probably have seen this, but here’s some data: Pupillary distance - Wikipedia
According to that, IPD range should be about 56.0 to 72.5 to cover 98% of US males.
Also here’s some data on different races, see paragraph 5.2 here: http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.62.6181&rep=rep1&type=pdf
Interesting though why the Vive pro has an IPD range 61.2-73.2. Maybe it was physically difficult to attain lower IPD because of the panel size.
Mine is 64mm here. Actually more like between 64-65mm.
Mine is 63.7 from the optician.
I have tested that card measuring with some old non working card. Let me assure you this method does not work or is highly inaccurate.
Mine is 58,5 from the optician.
I think I am at the lower end
I hope this IPD will be possible with the Pimax.
Enopho
16
Had new glasses last month re measured by optician. I am 68.3.
Eno
Cdaked
18
70 professionally measured two weeks ago by optician.
67 mm . 100 percent not sending that site a pic of my card though hahah
66 mm, measured with ruler and mirror.
