71 measured by optician
would not recommend 1 for valid results.
tried it a couple of times with 2 different pictures (demo card, not real one) and results varied between 61 and 64 which seems to be a not tolerable margin. Ruler method got me 62,7. As already mentioned though, IPD adjustment on Vive has not that much of an impact than on Rift and cardboard devices. Got significantly better results in adjusting the strap moving the HMD up and down.
BTW. what if one eye is furher apart than the other? wouldnāt it be better to be able to tweak it āeyewiseā? I could do that with the FIIT cardboard and got decent results.
AND just beeing curious
how much does the foam affect the relation between measured IPD and ajustable parameters on HMD? Since I get a significantly better sweetspot on vive using 6mm foam I have the slight Feeling that it affects IPD Settings as well
optrician measured 66,5
Pimax need those numbers just to know what range should be for IPD adjustment, therefore accuracy is not an issue here. Regarding someone with not symmetrical face, to properly deal with it individual custom face cushion is needed. Something, that it is not possible in mass product.
Shouldnāt you have asked this six months ago?
And Iām at 64mm
70 mm - measured by an optician.
64mm, measured by an optician
About 70, measured by not an optician
regarding a non symmetrical face this would have been the best solution (picture below) but I donāt think that it can be implemented on hardware basis for now
but there may be options to tweak it a little in software.guess the main point of the survey is to see how many plp get below 60 or above 70. since for example voodoode is on 60 and the settings do not always correspond to the actual IPD 1:1 I think it would be nice to have a little more headroom. Iām between 61 and 64 should be safe then
59
and iām wondering how even on this simple question ppl can raise a debate.
Itās Pimax asking for it, they will have a good reason⦠period.
In case you are in doubt they know what they do you really shouldnāt have backed the company and product in first place, think about itā¦
Itās strange though. I would have thought Pimax would have asked this question months ago, last year even.
Mine is 60. Measured by my father last time I ordered new glasses from ZenniOptical
66,5 by oculist (R: 34, L: 32,5) I think asymmetry is no problem so long as there is room for manoeuvre at the nosegap
@deletedpimaxrep1
Maybe there are medical or optician stats for every country to find out the average ipd and the standardised normal distribution of this value. (@sweviver numbers done again :p)
62.4 per Optician. for new glasses.
No to be EXTRA safe, use an ex-wifeās credit card
Haha, yes⦠however, if I knew where she was and could do that Iād have other plans for that card!
61 measured using mirror & ruler
Could simply be about best presets for western countries, or simplicity of the manual or options in manufacturing or debunking claims of beta testers orā¦
Between 64-65 as my Rift IPD setting tells me. Before the 8K arrives I will measure it properly at an opthamologist. But I guess I have a couple of months time for it.
Mineās 58-59 according to what I use for the Oculus Rift
67, professionally measured.
