That means quad views do not work ![]()
Unfortunately Quad Views is not supported yet. Silvan-CIG, the dev who is leading the VR implementation, is working on that, but no timeline for release yet as it takes some engine work.
He would also love to have full controller and ultimately body support eventually, but VR is an experimental feature atm. What we have is not the final implementation at all, just a version for feedback that works very well seated.
The latest test environment (called PTU, as opposed to Live) has some nice new VR features that will roll out to Live in the near future, including working 3D holographics for the radar system and so on, which are missing in VR currently. We currently test daily new PTU builds in the build up to Live release for 4.10.
Hey Octofox, it’s been a while! As you suggested, I’ve reopened the thread for updates.
Thanks great news ![]()
Latest VR compatibility updates of note in 4.10:
- FPS scopes - while still not the ultimate implementation (intention is to have PBR scopes I believe), these feel really good for those who are comfortable with VR FPS combat. Includes a zoom on / off system when looking at or away from the scope, if that makes sense, for increased situational awareness.
- Ship precision targeting mode - switching to this mode (right click while piloting a ship by default) incorporates a zoom and also allows targeting of specific components (internal components, engines, turrets etc).
- VR settings in the Options has a Zoom Slider value - setting this from 0.1 to 0.3 feels about right. Currently applies to both FPS scopes and precision targeting mode, but separate sliders are incoming shortly, possibly 4.10.3
- Silvan always details the latest VR updates in patches here, page is worth bookmarking in Spectrum: Star Citizen VR Support - Experimental Release (Alpha 4.8/4.9/4.10) - General - Star Citizen Spectrum
Frame generation:
- A new set of frame generation tools are doing the rounds, and currently wowing the SCVR community. These are new and improving rapidly all the time. VectorXR and OFXR Bridge are two. I’m personally trying VectorXR with the Dream Air and blown away by the increased smoothness whilst keeping artifacts to a minimum. Settings are a balance of smoothness vs artifacts vs input lag. I’m extremely happy with the settings I have now already, and there’s more to come. This is almost certainly the future of getting excellent performance out of demanding applications and high end headsets.
- Mal, the developer, is in regular communication on Silvan’s Discord. Latest incoming version v0.20 will read depth data which will improve artifact reduction even further, and also increase frame generation performance by 20%, so I’m looking forward to that!
- Forget your headset's smoothing option - VectorXR is here!
VectorXR 0.20.0 - Faster, Sharper Frame Generation, Turbo on SteamVR, and Eleven Languages
A major Frame Generation release. Generated frames cost noticeably less GPU time and keep cockpit detail sharper, Dynamic Interpolate can now use NVIDIA’s hardware optical flow with an automatic fallback, and Frame Generation is far more careful about the depth games provide. Turbo now works on SteamVR, where it used to switch itself off. The app, tray, On-Screen Display and installer are available in eleven languages. This release also includes every fix prepared for 0.19.4.
Frame Generation
- Less GPU work per real frame. Matching motion and preparing generated frames now take less GPU time. In replays on an RTX 5090 at 5424x5356 per eye, Frame Generation’s GPU time fell by about 20%, or 0.7-1.2 ms per real frame. In a DCS flight at 2x with shader flow, it measured about 0.6 ms per real frame.
- Sharper cockpits. Generated frames now use cubic resampling for nearby content in games that provide usable depth. In MSFS replays, cockpit fine detail in generated frames rose from 83-88% to 92-98% of the real frames’. Interpolate also keeps more valid cockpit motion through small movements.
- Dynamic Interpolate can use NVIDIA hardware optical flow. Choosing NVIDIA hardware as the motion source now applies in Dynamic too. A new option under Motion source, Fall back to Shader when hardware flow can’t keep up (on by default), switches Interpolate to shader flow when hardware flow repeatedly can’t keep pace, and tries hardware again later. Turn it off to stay on hardware flow. The OSD shows which source is active, and the log records why it switched. GPUs without supported NVIDIA optical flow use shader flow. In a 16-minute MSFS flight, Dynamic Interpolate on hardware flow held about 90 fps.
- Auto gives a lower multiplier a fair trial. A failed step-down attempt no longer disrupts the game for a full settle period, and a short burst of late frames during the switch no longer rules out a multiplier the game can sustain. Changes to settings, the runtime’s clock or the output images still get the full settle.
- The OSD shows when depth is helping. While generated frames use the game’s depth, the line under the Frame Generation row ends with “uses depth”. Depth that a game sends but that fails the checks is not noted.
- An adaptive lead ceiling, on by default. When Frame Generation times the game so far ahead that new captures replace images it still needs, the ceiling brings that lead down. It checks the result and backs out a lowering that keeps making frames late, so each game settles on its own limit instead of one fixed value.
v0.20.1 is expected to specifically support Star Citizen depth data, increasing accuracy and further minimising artifacts.
great! looking forward v0.20.1 support star citizen deepth data
NB: This build now supports Star Citizen depth tracking, however the depth data is confirmed as only being available in the new 5.0 branch, which is available for limited testing at present. A general release is scheduled before the end of the year.
