VectorXR (and the similar OFXR Bridge) are currently doing the rounds amongst the Star Citizen community. As the game is very demanding on both CPU and GPU, using a high end headset and getting good frame timings and rates whilst keeping quality is a challenge.
While the app offers many features, it’s the frame generation component that is the most popular. Depending on preferred settings, it is able to provide a level of smoothness with a minimum of intrusive artifacts. I can’t imagine not using it now, and it’s still very early days with a lot of features and improvements to come.
I have to say that I have never been a fan of Pimax Smart Smoothing - I find it provides smoothness in only very limited situations for my use, whilst also introducing horrible artifacts that I find hard to tolerate.
Now I have a far better alternative. It’s slick and works seamlessly in the background, with a nice clear UI and overlay. The developer seems to know their stuff, and is in close contact with game devs and the community to deliver the best possible experience.
Tune stereo depth and convergence through the Depth module.
Configure enhanced yaw and pitch rotation through the Pivot module.
Drive foveated-style rendering with a visible performance budget through the Quadviews module.
Override OpenXR runtime frame pacing per application with Turbo and compare strategies using built-in diagnostics.
Add optical-flow generated frames between real frames with experimental Frame Generation, so the headset gets a fresh image every refresh even when the game renders fewer.
Monitor application frame times, Turbo and Frame Generation state, and enhancements with a configurable in-headset OSD for Direct3D 11, Direct3D 12, and Vulkan games.
Create per-application profiles so different OpenXR games can use different settings.
Track OpenXR apps VectorXR has seen and register them as profile targets.
Bind feature toggles to keyboard shortcuts or detected input devices.
Inspect, enable, disable, reorder, and remove stale OpenXR implicit API layer registrations.
View VectorXR runtime logs from inside the app.
Check for newer VectorXR releases from the About tab.
Import, export, reset, and validate local settings.
@MReis asking @Heliosurge to unlock your SC thread so can update there about this. And other great things like VR updates to FPS scopes and ship precision targeting
VectorXR 0.20.0 - Faster, Sharper Frame Generation, Turbo on SteamVR, and Eleven Languages
A major Frame Generation release. Generated frames cost noticeably less GPU time and keep cockpit detail sharper, Dynamic Interpolate can now use NVIDIA’s hardware optical flow with an automatic fallback, and Frame Generation is far more careful about the depth games provide. Turbo now works on SteamVR, where it used to switch itself off. The app, tray, On-Screen Display and installer are available in eleven languages. This release also includes every fix prepared for 0.19.4.
Frame Generation
Less GPU work per real frame. Matching motion and preparing generated frames now take less GPU time. In replays on an RTX 5090 at 5424x5356 per eye, Frame Generation’s GPU time fell by about 20%, or 0.7-1.2 ms per real frame. In a DCS flight at 2x with shader flow, it measured about 0.6 ms per real frame.
Sharper cockpits. Generated frames now use cubic resampling for nearby content in games that provide usable depth. In MSFS replays, cockpit fine detail in generated frames rose from 83-88% to 92-98% of the real frames’. Interpolate also keeps more valid cockpit motion through small movements.
Dynamic Interpolate can use NVIDIA hardware optical flow. Choosing NVIDIA hardware as the motion source now applies in Dynamic too. A new option under Motion source, Fall back to Shader when hardware flow can’t keep up (on by default), switches Interpolate to shader flow when hardware flow repeatedly can’t keep pace, and tries hardware again later. Turn it off to stay on hardware flow. The OSD shows which source is active, and the log records why it switched. GPUs without supported NVIDIA optical flow use shader flow. In a 16-minute MSFS flight, Dynamic Interpolate on hardware flow held about 90 fps.
Auto gives a lower multiplier a fair trial. A failed step-down attempt no longer disrupts the game for a full settle period, and a short burst of late frames during the switch no longer rules out a multiplier the game can sustain. Changes to settings, the runtime’s clock or the output images still get the full settle.
The OSD shows when depth is helping. While generated frames use the game’s depth, the line under the Frame Generation row ends with “uses depth”. Depth that a game sends but that fails the checks is not noted.
An adaptive lead ceiling, on by default. When Frame Generation times the game so far ahead that new captures replace images it still needs, the ceiling brings that lead down. It checks the result and backs out a lowering that keeps making frames late, so each game settles on its own limit instead of one fixed value.
I’d like to know how this handles games in VR that are about 20fps (or slightly lower). Is there any benefit at all? Ideally I’d like to upgrade my CPU/GPU but apparently prices have hitched a ride on a rocketship to Jupiter.
It can help yeah, it has a 4x mode. Occasionally I hit ~22FPS in SC and it kicks in.
Ofc it’s best avoided to use 4x, it’s having to insert 3 frames for every real one so it’s the most visually intrusive in order to maintain smoothness. Most people are trying to avoid 3x and stick with 2x.
Using Nvidia optical motion flow helps reduce artifacts, but at 4x there’s no magic bullet.
So yeah, it will help with smoothness, but expect some degree of visual glitches until performance improves. It’s a last resort really. And of course this is using your GPU to do that work so if it’s totally overloaded already I don’t know whether it is viable. Need some overhead for this.
That said, I still find the visual artifacts with VectorXR to be far more acceptable than with Pimax Smart Smoothing, which imo is horrible. And VectorXR is still in its early days so significant performance and visual improvements are arriving with every update, and it’s already impressive.
When I use this with Xplane 12 my DA Slam controllers freeze in position. I can ‘trigger’ them but I cannot move them from where they were sitting once I started the game. When I turn off VectorXR everything works fine.
I don’t know, it doesn’t work properly for me at all—it stutters, and sometimes there are artifacts when I turn my head… I don’t get the hype; what’s supposed to be so good about it? 4090 and 13900K + Pimax 8KX
Well I don’t know what settings you’re running, what you’re playing, what your CPU/GPU performance is, so I can’t tell you if something isn’t set up right.
I can say that it’s working amazingly well for a lot of us where standard headset smoothing options are way, way worse. Getting super smooth performance with minimal artifacts, which simply wasn’t possible before on demanding titles.
There are small artifacts depending on the setting you’re running, but always better than Pimax Smart Smoothing, and it’s even less if you have Nvidia hardware and have the Motion setting set to that. Whether 4xxx cards are as effective (esp if they’re more at the limit) than 5xxx cards I don’t know.
This is using your GPU so make you have some headroom and therefore you’re on Dynamic, or Auto achieving 2x / Fixed 2x where there’s almost no artifacts. 3x and 4x are going to see more artifacts inevitably, but I still prefer it to Pimax Smart Smoothing any day.
I only play Star Citizen, and the 4090 is definitely not weaker than the 5090—the latter is a completely pointless card… I didn’t even get a chance to change any settings; it was just a total mess—it would stutter with every movement of my head. Pimax’s “Smart Smoothing” doesn’t cause any issues, but at the same time, it doesn’t improve anything on the 8KX either.
Hi, developer of OFXR here, and since competition is healthy and benefits everyone in VR ;-).
The new OFXR 0.3.2 is also signed and works in Star Citizen.
We are going to release 0.3.3 shortly for it, and it will bring more stability and visual enhancements.
Currently, until we release 0.3.3 in a couple of days, the best version for Star Citizen is still 0.2.14.3, with hybrid mode up to 4X + depth search and HUD fix, which greatly reduce artifacts.
Until 0.3.3 it out then:
And also curious to get feedback compared to VectorXR!
If you don’t feel the software helps you, you’re not obliged to use it But one tip: configuring things is usually a good way to get them working properly.
I am using Pimax EVO and testing in Star Citizen.
The dlls are signed and should go past EAC (Easy Anti Cheat), it was confirmed working by one of Star Citizen’s developer.
You might be running into a specific issue on your setup, feel free to open an issue on Github about it so we can have a look!
0.3 versions signed and working for SC from 0.3.2 onwards.
0.2 versions signed and working for SC from 0.2.14.1 onwards.
Ok but to clarify, I’m not using the sboy3 driver with SteamVR. Just bare EVO/PimaxXR. Just tried it again and Star Citizen launches with VR support not enabled which indicates a EAC issue.
Yes, I understand and I just tried again to be sure with both Pimax OpenXR and sboys3 in EVO. Both working. Also when EAC blocks OFXR, like for previous versions, it does not block VR support.
So it seems there’s something specific about your setup. Are you using other OpenXR layers? If you used VectorXR, you need to disable its layer first or it might conflict with OFXR.
Happy to help you diagnose. Best way would be to get a log from you and open an issue on github.
So you mean PimaxXR from Mbucchia? If you mean Pimax OpenXR in EVO, that’s also something I tried and it works on my side and other users I know. I would be happy to help but I would need a log from you and the best place to send that is on github! I you have some time, I invite you to open an issue there. Thanks!
