Pimax Crystal Super Ultra Wide - Only getting 120ish FOV
I’m only getting around 120 degree HFOV with the Pimax Crystal Super Ultra Wide.
And that is with the thinnest facemask and the headset super tight .
Anyone else? I have tested in several different test programs (TestHMD & WimFOV)
I am a long time Pimax Crystal OG User.
I made a detailed analysis in Crystal Super UW issues / analysis / comparison with 8KX
@PimaxQuorra can we have the new Pimax crystal super ultra wide profile to test ?
Please check the DM.
For me I just had to lower the IPD while the autmatic ipd was 71.7 with 68.5 I got HFOV132 to VFOV112 instead of HVOF116 to VFOV90, but i really getting into Performance issues in VRChat, other then when using the 5k Super or the Vision 8k plus, I had to down scale it to 5k to be able to use the Super in VRChat, i didn´t tryed other games yet with the original Resolution, also i can´t lower the Image Resolution the Middle, while its otherwise not sharp enough any more
rest was set up like on the 5k and 8k
My Issue is that if I don´t downscale my 16GB VRAM gets filled fully and I have an 5080 OC
Or do I need a 90series to be able to use the potential of this VR XD
I have similar numbers. My personal measured IPD is 67.0 mm. I am not really sure of what software mods I need to do to get a bigger FOV out of the headset…
Changing your IPD away from your real IPD does physically increase FOV, but most of that extra FOV is optically invalid because the distortion correction was calculated for the proper eye position, so the extra view is stretched, warped, and not truly usable.
I doubt in that. I have the same Gfx card and in most scenarios reaching 12GB video ram usage.
I"m playing mostly racing sims like iRacing , LMU, Dirt Rally 2, ACC and also flight sims like DCS and Il2
For instance : for LMU , my setup is 100% res, ultra textures, rest medium and is very stable, but I’m using pimax oenxXR. 0.44 and toolkit 1.38 with enabled CAS ,cro2fov and fixed fovated rendering . Mbuchia apps are working 25% faster than pimax client adequate features
Maybe you should clarify what you meant by “5k”. Is that 5k per eye or total?
5k total is quite a low resolution, and 5k per eye is a pretty good setup. Huge difference here.
oh yes i mean by All, sorry
Also a friend of mine were able to help me, after activation of Dynamic Foveated Rendering on Custom with HGAR (40%) / VGAR (50%) / GAR (150%) / PAR (70%), Pimax Central Priority Rendering on Quality, Upscaling NIS on Balanced, Image Quality on Customize and in Steam the setting 4K per eye, to achieve only 12GB Usage in VRChat
Hi everyone
My Super UW have a Fov H = 137,8H with 11mn Foam,data read in Pimax XR .
i LOVE my super UW ,in DCS /Lfs 2024/Il2 Battle of Stalingrad and iracing, i win 3 cm in Left/right Horizonatl display game .(i look my left/right Tires finally in my #Super Formula Light (no Fixed set up )
Better for a good immersion vs my Super 50Ppd and my Crystal og (better in dogFight in Simflight military( IlL 2 bob /il2 flying Circus /Dcs world
I’ve a RTX 5090 MSI Suprim X + Amd 7800X3D /64go ram ddr5 Corsair Vengeance RGB 5200mhz /samsung 990Pro 4TO .
Aplushhs /Laurent :france:
Ok So apparently, my last measurement was incorrect, today I visit at an optician and got my IPD.
The Super always Set my IPD up to 70.4mm but it was wrong, since my IPD was meassured the official way today at an optician and got 66mm measured.
So with an IPD from 66mm set in Pimax Play, I only get 120 HFOV and 108 VFOV
Same for me. I received two super UWs and the changed profile, but in the end it was always only around 120° HFOV. I decided to give up on the Super UW and switch to Micro Oled. It was not just the missing FOV, but also the terrible Mura. So much worse compared to my OG Crystal.
Please report this to our support team, and they will help you switch the order to micro-OLED.
I had 120 with the gift silicone face pad installed. After switching back to the standard one, it became 130+. In general, the FOV is very sensitive to the distance from the eyes.
Thanks! I did. Just waiting again and again for a response. Sometimes it’s two days, sometimes five. I received the first suoer in October and I am still waiting to get an engine that finally works (OLED). I already asked to extend my warranty, because I have lost 4 month without beeing able to use the headset faultless.
Are you switching from silk face pad? I thought the thin silk face pad is the reason I got a bigger FOV. The standard is actually thicker…so I am not sure what you’re saying.
If you haven’t heard back by tomorrow, please share the ticket number with me.
I think some faces just don’t work with the default interface. I had the same problem as you with the super ultrawide. Couldn’t get more than around 120 FOV. I started using small FOV settings by default because it wouldn’t make any difference.
Then I received the OLED module and I couldn’t make more than 105 FOV. Trying the silk mask, the default thin mask, the studio form mask and another cheap one bought online…
That’s when it hit me. I took the face interface off the headset and when pushing my face closer to the lenses, to the point my eyelashes would almost touch the lenses, I got to experience the full FOV on both modules.
The reality is the default face interface doesn’t fit all faces. In my case my cheekbones prevent me from getting close enough.
My current solution: I cut the foam from the bottom of the face mask foam and now I can experience the full FOV while loosing a bit of comfort.
Better solution: modify the 3D model of the face mask provided by Pimax and print a custom version. A redditor will help me with that. If I can get my face 3-5 mm closer to the lenses that will solve it.
I hope Pimax will provide different variations of the facial interface in the future.
We’re currently reaching out to several aftermarket comfort mod partners, including StudioForm and AMVR.
While we can’t promise their facial foam will be a universal fit, it should at least give users some alternative options to choose from.
