guppyexpress & DrWilken >> Thank you for your help.
It started working at 120hz.
Good DFR response speed and drawing results!
you are very welcome!
i hope that my custom firmware fix for the eyetracking helped you
You are the first to say something positive like this.
Can you link me to the guide you followed?
Did You check the title of the thread� ![]()
Go to first post⦠![]()
Oh, and I was actually also positive (way back when I received the module) and even mentioned being able to use 120Hz with the included cable.
EDIT: Actually, I found the post about 120Hz and You liked it⦠![]()
https://community.openmr.ai/t/eyetracking-module-woes/34573/19?u=drwilken
Lol thereās so much negative about the eye tracking I forget that there are something good from time to time.
I have not yet had a good experience with it so Iām trying one last time before ripping it out for good.
Iāve had good experiences with it, but I doesnāt work with the titles that need it the most (not Pimax fault) and I found the glare it added annoying, so it actually took me a while before I installed it on my replacement 8KX after getting it replaced recently⦠
This thread was actually what made me want to revisit⦠
I think it works fine when properly configured, but nothing jaw dropping⦠
If it works in Your favourite game, I think itās worth the hassle.
Hello,
Thank you for all your work on timproving tge eye tracker. I have two ETs. Can we have the serial numbers (up to) of the ones that are before the revision?
Kind Regards,
Pat
Hello Pat!
I will not be providing the serial number publicly to non Pimax staff. this is because the serial number is kinda a private thing. there were several revisions along the lines of the eye tracker. for a while back in 2020 and some of 2021 the eye tracker was temporarily discontinued. this is where the biggest revision took place. whichever eye tracker was purchased after that date is most likely to work with this fix. the older ones will still work, but not be as accurate as the newer ones.
For Everyone who would like to develop for the DroolonPi1
here is a website documentation I have set up to better help others with developing programs for the Droolon Pi1
(the website link to the online non source code documentation is in the readme file on the bottom)
I hope everyone here enjoys!
Hello FynnKitty!
the fov with the latest revision of the eye tracker is slightly larger than the artisanās widest fov
For everyone who plays Neos VR
here is a mod to allow you to use the eye tracker in NeosVR.
speaking of eye tracker, there is a certain update im working on that will make it on par if not better than Tobii, will post later when completed.
For Everyone who was wondering about a comparison.
this is what it looks like in vrchat with an unfinished eye tracking mod that doesnt have smoothing or multithreading
this is a great comparison to what it used to look like!
Hello! That mod is currently broken
I have partnered with someone to develop a newer mod for it. At the moment that is only in beta testing, it is still having some problems. Once it is finalized I will announce it on this thread.
If you would like the current most stable build.
Shoot me a dm on discord @ guppyexpress#0001
Does it work with Automobilista 2? Itās the only game I spend most time on. If not, no reason for me to look into this.
Hello reptilexcq,
have you tried FFR on Automobilista 2?
if FFR works, then DFR will work on that game with the eye tracking
I havenāt even opened it. Thatās why I ask to see if anyone may have tried it.
Have you tried FFR? Doesnāt require ET. If that works then DFR should work.
Sorry, how do you access FFR without Eye Tracking?
If you have an RTX Nvidia card FFR option will be available in pitool. So RTX 2000 series or rtx 3000 series cards.
FFR does not require ET.
If your using a GTX card or Amd FFR is not available.
I tried it, it doesnāt do anything. It has no effect. How do you know if it work?
