It will depend on the title. Try agressive it may look pixelated.
If so reduce from aggressive. I inly have a gtx card si might need someine like @MikeJeffries @Ludiks to weigh in
I turned off FFR when i tried it. Youre better off just lowering the FOV than having that blurriness on the edges. It makes no sense to use it FOR ME.
I am not feeling anythingā¦it looks normal to me. I tried aggressive, passiveā¦it has no effect. I thought youāre supposed to use Eye Tracking to see if it work? I even tried it on PE and BigScreen and they have no effect.
u must restart the vr application in order to see anything. example would be if you are playing beatsaber home and you want to enable FFR you must enable it in Pitool, apply and save. then exit beatsaber. then re launch beatsaber
it will be visible
the blurriness is a lower resolution to help increase frame rate. but since you do not have the eye tracking you would use FFR also known as Fixed Foviated Rendering. which means the fuzziness if fixed to the side of the visuals and gets quite annoying.
with the eye tracking it uses DFR also known as Dynamic Foviated Rendering. in this way it follows the eye movement so that you do not see the fuzziness on the edges as the human eye naturally does this on its own for peripheral vision, but the computer can not replicate that without eye tracking to provide the data on where your eye is looking. naturally the human eye has a small circle that is actually the most in focus, and the farther from that focus point the fuzzier it gets. Dynamic Foviated Rendering causes this to happen to VR to help better your frame rate. But because you do not have the eye tracking you can only use Fixed Foviated Rendering, so that the fuzziness is only on the side and can not naturally move and mimic your real life eye movement.
Iām an AutoMobilista2 player. FFR and DFR do not work.
FFR(DFR)not working
AutoMobilista2
EuroTruckSimulator2
iRacing
MSFS2020
FFR(DFR)working
AssettoCorsa
AssettoCorsaCompetizione
DCS
KartKraft
No Manās Sky
VirtualDeskTop
Okay, thanks for that info. Now I can put my ET on the shelf.
Update: it was already on the shelf lol.
Never tried FFR yet since I only used GTX series also.
Until gpu prices drop, which is not tomorrow unfortunately.
I also located where I threw the box and recently shelved it. Never got it to work once and all the unit did was warm my eyeballs and cause reflections.
Waste of $$
Have you tried the FFR with that openvr_fsr mod? Apparently it works on all cards
Didnāt know about this, I shall give it a try when I have a chance thank you
DFR works in vrchat for me
Is there a ETA for a āwholeā Software/Driver Package Update? Would be nice to have an offical update that brings all together in one solution.
would be great to do that, after the AI learning system can be designed for this so that it will perpetually get better. have some wonderful things im cooking up for it
I bought a Pimax 5K Super to work together with my Laptop (i7 11th 8 cores and RTX 3070) and the choose was made by the natural limit of mobile gpu implementation. Using ACC (Assetto Corsa Competizione) to get something around 80 to 90 FPS I have to use DLSS2.0 that gave me a better balance between performance and image quality. The problem is that one concept clear in racing game or alive is look ahead where we are going after the next point and the resolution for that is not the best. The marks of 300, 200, 150 and 100 meter appear readable only very near. DFR would be a good solution but as everything in this world it is not so simple.
I live in Rio de Janeiro Brazil that is a very hot and even with AC in my room I need just a few seconds to foggy all lenses since I use glasses as well⦠The ageā¦So installed a little fan snorkel in that and it is perfect. The problem as I could see is that it is in the same place that Eye tracking device is installed. Is there someone around this little world using both together?
Sounds great. Any update on a regular SW release in piTool so far?
I am looking forward to buy an Eye tracking module for my 8KX if the updates are available ![]()
Maybe a stupid question, for the original 100hz firmware, does that forward.exe need ran every time you want to use it?
both the software Pimax provides, and the software I provide, require Forward.exe running in the background yes
Hi!
So, I picked up a eye tracking module ā mostly for giggles, but I mean its a gadget so I kinda had to play with it. By default, yeah, its a bit⦠lousy. So I put on this firmware (easy enough) and its very different. I might need to calibrate it a few times to get it just right, but its already worlds different than the stock. Nicely done!
Itās not applicable to the first batch of eye trackers, is it? Or is it? Honest question, being one of those who kept pushing F5 as soon as the eye tracker was launched.
It should be compatible with the first batch of eye trackers, yes
