The X:
Not the final version, without comfort kit and rubberized housing.
With a 2080, the resolution if outstanding, native is a thing, sharper than anything else.
The SDE is negligible, but you still can see it if you focus on it, better than anything else I’ve tried.
Unfortunately there was a problem with the cable and the picture was very dark, almost like the 120Hz mode on 5K+. And the games crashed a few times. The colors were muted and brightness very low, I’ll come back tomorrow to try it with a good cable. The cable was glued or bad attached to the headset.
I tried it with DCS and Pavlov.
Not problems with refresh rate, and distortions much better than 5K+ and XR that I own.
The +:
Same SDE but not as sharp as the X, It was very noticeable in the cockpit and textures. But it’s great, much better than 5K+.
I tried it with DCS and The Blue.
The comfort kit is great, very comfortable, I put it, set my Ipd, and everything looks great.
I didn’t heard anything, maybe the volume was very low or the speakers are not good at all. But thumbs up for the comfort kit.
Materials, coating and housing; it’s great, it definitively looks and feels premium.
The blacks were bad imho, I think worst than 5K+, specially in The Blue, in the abyss, and in the steam vr loading page. I know very well these two scenes on my 5K+, maybe the brightness was too high in Pitool.
XTAL:
Not very impressed. I was in a bright room. Good SDE, good brightness and colors, but I didn’t like the FOV, specially the vertical, very high cushion in the center. At the beginning I had double vision, after automatic calibration it was better but it didn’t feel right at all. Much better the 8K X and the + imo
Varjo:
With a flight simulator, outstanding resolution at the center. At the beginning I could see clearly the difference between the two screens but after few minutes the difference was not apparent anymore.
Very small FOV.
Overall I’m really impressed with the X, I hope I’ll can try it tomorrow with a better cable, and very impressed with the comfort kit and new housings as well.
