According to multiple sites (for example https://www.vrheads.com/field-view-faceoff-rift-vs-vive-vs-gear-vr-vs-psvr) it’s 100 horizontally. I haven’t tested it my self though, hmm good test actually, will measure later today on my Vive Pro with Oscar’s tool
yeah sure your sites vs mine
http://www.vrtalk.com/forum/showthread.php?1282-The-Field-of-View-Argument-Rift-Vs-Vive
Your link is dead.
You might be right though, haven’t checked it myself, will check later today on my vive pro with oscar’s tool.
It was properly measured vive vs rift . Ofcourse Vive wins.
Dont trust sites which give you the round numbers. They usaully replicating news given by devs
Your link is dead. I don’t trust any number until I measure myself
Will do so later today and will let you know. Could be that it’s 93, I don’t know. But what I do know is that that still wouldn’t explain the weird pics from Voodoo
Yes, ‘bad gateway’ error here.
Works OK for me. 20 characters.
Yes I guess you’re talking about that first pic, there they claim 93.5 Which could be because if 200 vert is 170 hor, then 110 vert would be 93.5 hor and by that same logic 170 vert would be 144.5 hor. In other words if that’s correct then the pimax normal mode will be 144.5 horizontal by that same logic.
Read Doc-ok paper on FoV measurement as it will vary a fair bit from user to user. Due to pupil to lens distance.
Both statements on FoV are true.
Repeat test with thicker & thinner foam.
What kind of test would that be? Repeat test with one eye half closed the next test? Come on that’s nonsense Helio.
If you want an honest pic, then draw a pic with a 54.5% bigger FoV for the Pimax at normal mode. That’s what it is. Not 100% like in Voodoo’s pics.
So its 51 degree larger than Vive right ? also larger vertically , how munch i dont know exacly but seems to be around 20~30 degree.
also I tested 170 degrees mode in Berlin and for games like Assetto Corsa , ED , IL2 distortion wasnt bother me at all it was EVEN hard to notice them on sim games . I have to say its better to have this Large FOV which you deny than don’t have it at all.
I don’t deny anything. I just mentioned that the 3 musketeers all prefer normal mode and use the pimax in that mode. So that kind of tells me that’s probably the mode most people will run it on.
Most yes , but i’m going to use mode which gives me advantage in dogfight or chassing in sims.
Large Fov in some sim games should work great.
Well if the added distortion doesn’t bother you or you don’t even see it at all (like some people claimed) and your gpu can handle it, then sure. But from what I’ve seen the fastest gpu’s struggle enough already as it is with the Pimax 5k at normal mode.
becouse in some games is even hard to notice them , like ED
Look it up Doc ok did tests on eye distance to lense. If affects fov. Will see uf I can find the article.
I would hardly call Doc Ok nonsense.
