Yeah, surely if you crank the PP resoltution right up then even if it becomes an absolute slighedshow it should be extremely sharp?
I’m not home to test it yet, but is there a motion blur effect on perhaps?
This guy mentions disabling it:
Go to Documents\STAR WARS Squadrons Steam\settings
find ProfileOptions_profile and open it with notepad.
Now search for the text line that says “GstRender.MotionBlurEnabled 1” and change the 1 to 0.
The PP blurring in the X also reaches a new dimension with XPlane.
no difference to the 8k +. But Laminar Research thinks Valve should take care of it with SteamVR. Valve have it in his hands.
I agree, it reminds me of Half-Life Alyx quality textures & lighting.
Be sure to say something here about PP if you haven’t already: Oh no! Pimax headsets need parallel projection! Devs please fix this! :: STAR WARS™: Squadrons General Discussions
Also, just out of curiosity, what platform did you guys purchase the game from? Steam or directly from Origin? A number of people are saying it runs better on Origin, but it’s likely not to change anything for non Rift headsets. Maybe if it’s run through PiTool instead of SteamVR? I’ll order the Origins version to test this out later this evening.
I just ran it for my first time and i get it, the blurriness jo is complaining about is not from the parallel projection and I’m confident most if not all headsets are dealing with the same muddy quality.
it’s clearly a combination of TAA which cant be disabled and the frame pacing problems giving a kind of motion blur/double image similar to what you’d see with smart smoothing but of course smoothing is disabled and fpsvr shows full framerate.
this one is going to require a patch for sure or at least some savvy ini/console tweaking to sharpen it up, until then we all are getting the PSVR experience
Aww that’s a bummer to hear. Hopefully it’s fixed soon enough.
K I saw the stuttering for myself last night. fpsVR was always at 75fps (Average 74.7 or something) even with lower SS/settings…but it looked good with parallel projections at the SteamVR recommended numbers.
I noticed that lag in Pimax headsets just look like framdrops, where other headsets I can “feel” the framedrops, so it’s not too annoying, but would like it smoother.
I’l look into this today and see what I can do.
Here is a comment from steam forum .
Playing on Rift S (with a GTX 1080). No problems here feels great!
For the very first boot up start it in 2d mode and change to VR via “Toggle VR” when you are in the first mission.
To anyone having issues with the Rift S , I can confirm that playing it through the Epic launcher is 1000 times better than using steam VR. The choice is either an unplayable experience or feeling like you’re actually flying a tie-fighter. I know which one I chose. refund that crap. I can’t imagine why there is no native oculus support on steam.
maybe this will help
We are not playing on Oculus headsets here… This is a Pimax forum
but pitools has revive baked in, someone could test the game using oculus mode with pimax rather than steamvr
i tried it now on the 8kx and on the valve index…
it did feel better on the valve index(also because off the exellent sound off the index)
And also because off the higher brightness off the valve index…Explosions etc have a alot more impact with the higher brightness
Cant wait till my hp reverb g2 arrives and see how it looks!
Dirt Rally 2 had junk performance on SteamVR for a good while after launch as well. All resolved now.
I set a custom VR graphics setup to balance performance and visuals, sitting in a Practice session and watching FPSVR. I noticed the shadow option was very heavy and I set it to Low.
Other options really depend on what responses I saw, some medium, some high, a couple of Ultra ones. If anyone can’t find satisfactory settings I can go and check them.
I’m not seeing any particular game-related blurriness, but some stutter here and there - certain parts of the cockpit and near large ships. I’m still using an older Nvidia driver and not the latest Squadrons one, if that makes any difference.
@JoCool I didn’t get a mouse cursor in VR but I was able to get the mouse to select certain options that that HOTAS wouldn’t eg when in the Social screen. Kinda weird. I used a combo of HOTAS and keyboard that worked OK for me.
Findings from general play and then trying to get a co-op session going with a friend.
- Practice and story mode work so far
- Fleet Battle training quits the game after the first cutscene where the ship takes off. End up back in SVR.
- Fleet Battle solo works OK
- Dogfight multiplayer also quits the game after the first cutscene where the ship takes off. End up back in SVR. My friend in pancake did not experience this and he continued into the match with others.
- Edit: Fleet Battle Multiplayer works OK, although it did crash once after my ship was destroyed
Interesting. Do you guys also have the stars / skybox be super blurry?
In the Vive Pro they are crystal sharp. (P.s. on a different system,maybe it really is a setting!)
stars / skybox be super blurry? yes it is , pimax 8kx
Yes exactly, like fluffy powder pillow stars instead of sharp dots.
Yes, the skybox is very blurry on my Index also
