All right all right calm down man. I wasn’t accusing you, was just making sure and trying to get a fix for you.
The bug report forum is here: https://answers.ea.com/t5/Bug-Reports/bd-p/star-wars-squadrons-bug-reports-en , if nobody else has posted by the time i get a chance to test it myself tonight and gain some specificity on exactly which effects are broken without PP I will make the report.
otherwise whoever does it first paste the link here so we can pile on and vote/reply!
if you read through the Steam reviews, other HMDs also have their problems.
The control should also not make sense.
Can not test, only read some things this days
yes i do wonder if he’s not just upset at the frame pacing/vsync problem everyone is having as much as he is about the pp penalty
And he’s not wrong that Pimax should deal with all devs proactively to stop PP being needed.
yeah, EA was probably afraid of losing his “good reputation”.
that’s a fact. pimax should be actively working with studios especially on AAA games to ensure their developers have the knowledge and tools they need to not ship broken code even if that means pimax paying for it!
i would expect @anon57422158 to be the one spearheading that effort by now, sure maybe make a “consortium” of manufacturers of hmd’s with canted screens than can combine their influence. vr is young and i work with lots of experienced devs that just dont think about these things, they dont even have their own headset at home they’re just grinding 8 hours a day with a rift-s next to them at the office and if it works on that they close the ticket and move on.
until then we users have to make bug reports and re-open those tickets
Also Xtal, StarVR and any other, who will go to wide FOV…
but wait, ohh, wide FOV are to expensive for the big Companies.
PP looks bad in every game.
It’s the opposite of a sharp picture. The max sharpness you can get from it is on 5K+ levels. Even if you ramp up resolution.
So it is a Pimax problem, it’s not exclusively tied to SW Sq.
Fire up your 8KX and try it. Tell me how you can produce a sharp picture in any game.
Yeah, maxRR is on 16K already.
No, it’s a game programming problem.
Parallel projection is the only way to use these “bad” games at all.
PP is a Hack.
The alternative has StarVR, they don’t even run there.
Incompatible
So does the skybox look better on the Index?
It really is pretty bad in the 8KX.
I was so excited to play STAR WARS: Squadrons on 8KX … but if it is worse experience than Index due to parallel projections … then guess I’ll have to wait for Reverb G2.
Please contact EA … send then a few 8KXs and give them technical guidance so they can make it not require parallel projections.
So is there a way to hack the engine itself? Then we can’t play MP for getting banned, right?
the hack would be to write EA, which is crap and avoid the game as long as it is.
I don’t know if Valve are even trying though, I think they just take the (in their case) 5% hit.
I liked the idea of building a consortium of canted screen manufacturers including valve to provide training and resources to studios , all they have to do is fix their code to work on an index with their pp disabled and it would also work on pimax, starvr, etc
One of you can possibly try this, even though we’re playing in VR.
“Sorted mine by forcing v-sync in nvidia control panel custom profile, then setting it to no v-sync ingame. 2080 at 2k + 135% super-sampling using g-sync with a steady 165hz/fps with zero stuttering or issues. Once I got it running well it was a surprisingly well optimized game. Hopefully this helps a few folks…”
“Go to your Documents, look for the squadrons folder and edit the files BootOptions and ProfileOptions_profile with any text editor. Look for GstRender.EnableDX12 and set it to 1 in both files. Idk if this helps with VR but it made the game a lot smoother for me. Also make sure HDR is disable ingame, if your headset cannot do HDR.”
That’s advice for monitors. Thanks, but doesn’t help. I’m just incredibly frustrated the game doesn’t support canted, and that PP looks unsharp - wherever you go, whichever app you use.
If PP would look sharp, and not have this subtle blur to it, given I put higher Res in than without it, everything would be fine.
I got the horsepowers to race the cart with just 3 wheels, but it’s no use if the picture is blurry in PP whatever you do.
I was waiting for my 8KX and hoping it would arrive in time because of this game.
I don’t get what you mean about it not being sharp with PP on. I typically have PP on for a lot of my games and they look absolutely fantastic.
