Pimax Play v1.43.4
Pimax Play v1.43.4
Download: v1.43.3
Release Notes:
I. New Features and Improvements:
  • Added support for the Crystal Super Micro-OLED optical engine.
II. Fixed Issues:
  • Fixed known issues (coding)
III. Firmware Update:
Crystal Super Firmware V1.0.12:
  • Improved video stream connection stability.
  • This headset firmware is only eligible to micro-OLED optical engine. Other Crystal Super will not receive a headset firmware update prompt.
IV. Rollout Plan:
  • This version will be gradually rolled out to all users over the next two weeks.
If you want to rollback to earlier version, please download from here: Pimax Play 1.43.3
With this version (as well as 1.43.3) I have a constant flickering when using Quadviews. As if the foveated area is constantly switching on and off causing the edges of both areas blinking. I also have a lot of head jitter. This was not the case with 1.42 version
In DCS? Could you please share screenshots of both your Pimax Play settings and your in-game settings? This will help us try to reproduce the issue under the same conditions.
