Pimax Play v1.40.4
Pimax Play v1.40.4
Download Link:
https://dlappstore.pimax.com/release/play/PimaxPlaySetup_Release_ToC_V1.40.4.138_202507171814.exe
Release Notes:
I. New Features and Improvements:
  • Added a quick room setup function.
  • Added local dimming feature for Crystal Super.
  • Reduced CPU resource usage.
  • Improved in-app translations.
  • Optimized System UI visuals.
II. Fixed Issues:
1. Crystal Super & Crystal Light:
  • Improved SLAM tracking stability.
  • Optimized controller’s minor jittering issue.
2.Crystal :
  • Fix the problem of random crashes.
III. Firmware Update:
1. Crystal Light Firmware V1.0.18:
  • Improved headset connection stability.
IV. Rollout PLan :
  • This version is planned to be gradually sent to all users within the next two weeks.
Is it normal that, with this update, my Crystal Light 100% resolution in Steam VR is now 4468 x 4800 instead of 4312 x 5100 ?
It’s showing 4312 × 5100 on my PC.
Is the render quality set to “High” in Pimax Play?
Yes, in Pimax Play I tried disabling quad view, FFR and Hide Masked Area, while changing from High to Custom 1X and nothing changes.
Consider that I also installed the latest firmware for the Crystal Light.
Please take a screenshot of your Pimax Play device settings and your SteamVR settings for me.
I also tried with 120Hz mode, but I had the same resolution
Hmmm.
Have you tried reinstalling SteamVR?
I’d also recommend filing a support ticket and including your log files so the team can analyse them.
are you using openxrtool, might be the crop function. I also had a different resolution, after a clean installing of pimaxplay, removing all appdata and all before…it came back
It could be.
@PimaxQuorra Sry for the off-topic. I set notifications for this topic to “muted” but I still recieve emails for every reply and it spams my mailbox. I can tell I never asked to be notified, it’s been months I didn’t come back here.
It’s like if an admin set notifications for everyone and overrides our personal settings, I don’t know.
I tried to uninstall Pimax Play, delete all the involved folders and reinstall the latest version, but now I have even a different resolution value! 4468 x 4756
This is getting weird.
This evening I’ll try to reinstall Steam VR too and report back.
I never had open xr toolkit on my system.
Can you manually change it back? I think it is SteamVR that is causing the problems. Are you using the beta SteamVR?
When I manually move the slider away from 100%, I never can achieve the “couple” 4312 x 5100. It is like the proportion is different now.
When I try, I achieve something like 4500 x 5100.
try adjusting the pitool render resolution like 1.10 and restart steamvr
Nothing was recently changed and admin setting of categories takes priority with your setting choices ..now the Forum mail server was down for almost a year and only in the last month or two fixed.
A quick look you shouldn’t be receiving any emails going by your settings. If this persists may need more details
Did see any muted categories except the uncat.
@Heliosurge Could you take a look at the mail settings?
Thank you.
