Pimax Play 1.44.1
Smart Smoothing is disabled, right?
Noted. This should be an easy fix.
Noted. I’ve asked the devs to take a look at the ticket. If they need any additional information, we’ll reach out to you.
It was related to the display streaming logic.
also, what exactly does the Quick fix for USB Selective Suspend do? Because i first tried the manual options, disabled it on all power profiles, but the diagnostic still reported it as enabled. Quick Fix did complete it.
Not had chance to benchmark any games yet, but for me this update appears to have fixed the disconnect/black screen issues that I was having with my micro oled.
are you for real PIMAX!
this update also breaks 90hz for me! disconnecting and connecting in an endless loop until I switch to 72hz! :enraged_face:
ridiculous!
update: looks like same issue now with 1.43.9 and 90hz selected.
This may help resolve some connection issues, as enabling this option can sometimes cause USB errors with the headset.
Did you encounter the disconnection loop while running at 90Hz?
The devs are already looking into it. It appears to be related to the firmware update.
I run a batch file that auto disables all USB sleep settings across all USBs. Runs on each login. You never know when a program or USB device will set its own settings.
Hello,
Could you please export the log files for me so I can forward them to the devs for further debugging?
No. I only use 90hz and it seems fine
can you share your .bat file?
I also created a ticket with attached logs: #131001
So, no one can answer my question: I heard many reported issue with the Super Micro-OLED with this firmware/software update. What about Dream Air? Hello?
I play Skyrim MGO mod and ever since the beta update I tried I was no longer able to use openxr and was forced to use steam vr. I can now bypass it with this update performance is also better
So far, Dream Air users haven’t reported any major bugs with this patch.
Thank you.
Put both files in the same folder, then double-click InstallUsbSleepTask.bat. It’ll prompt for admin, copy the PS1 to C:\ProgramData\DisableUsbSleep\, register a scheduled task called “Disable USB Sleep” that runs as SYSTEM at every boot, and run it once immediately.
