Now Available: Pimax Play 2.0 Open Beta
It was definitely enabled,
On Assetto Corsa I get this error message after the crash.
I won’t do any more, I don’t want to waste time getting frustrated.
I reinstalled OpenXrToolKit but it didn’t change anything, so I’m going back to Pimax Play 1.43.
Well it’s not working on my 8KX. When is this going to be fixed?
I have the exact same error with openxr toolkit & Assetto Corsa
installed the new openxr toolkit crop/3dboost mod and pimax play 2.0, safe mode to openxrtoolkit and reset settings and it should be working
This has been rolled out to all users. Simply enable the “Public Test Channel,” and you’ll receive the update prompt.
Those preset values have not been changed in either Pimax Play 1.x or 2.0.
Let me report this to the dev team.
We may not have these two games in our library, but we can try reproducing the issue with other games using UEVR to determine whether it’s game-specific or a more general issue.
What’s the GPU driver version? The latest one?
Make sure you have the v595.9 installed.
It is prepared on beta 2.0, foveated crop ( up and down separated sliders)? That was a feature promise in the past and very very useful
I’ve had the Beta 2.0 version for a while now; is this different? To get it, do I have to revert to the stable version and wait for the notification, or will I get it by continuing to use the Beta 2.0 version that I already have? Thanks.
You need to revert, then toggle the public test channel switch
Yes. Was running 595.95 and just updated to .97. Smart smoothing still doesn’t show up. I’ve sent you my logs via DM.
I managed to launch Assetto Corsa Evo but not the first of the name with openxrtoolkit
I really like the look of the new galaxy you guys added in 2.0. When I had tried the beta originally I did not feel like it was ready, but on this one I think we are making some good progress. I did notice a few weird glitches that I plan to see if I can recreate later today before I report anything. I just want to use it for a bit.
I am having the same issue (Assetto Corsa)
Question for everyone: Is it worthwhile to participate in the new updates and tests if you’re using older VR headsets like the Pimax 8KX :red_question_mark:
Thanks!
when changing sharpness value, home environment goes to defaut even if it was off :smiley:
same thing with custom resolution
Feel free to give it a try. If the performance doesn’t meet your expectations, you can always roll back to your preferred version.
Since this isn’t headset firmware, the rollback process is quick and hassle-free.
Please’ for whom that use two differents headset, create a profiles to shape accurate settings for each one. And hope you introduce vertical cropping to gain performance
Hi,
Are we not supposed to see something when into the headset, with this new Play 2.0?
I mean, in mine (Crystal OG), I don’t see anything but a black sky full of stars, but no Menus, no Interface, nothing.
Where or what is supposed to be the NEW Pimax Home?
