Problem is Pimax is using microsoft generic usb Audio drivers. Ppl have requested for example Microphone boost added to pitool. Since Pimax is not using there own driver we are limited to Microsoft as it seems pimax is unable to create there own audio drivers.
Otherwiss this could be made to work. But pimax has to stop using generic windows drivers for both Sound ans microphone.
The noise Timo.H1 videoed is the same noise/tone Iâm getting. Use an FFT analyzer. Itâs around 1.7kHz. The odds of this same tone on two computers would seem to rule out random computer accessories are creating the issue (unless itâs picking up noise from a basestation). Itâs seems to be an issue with the DMAS. I didnât hear it with the SMAS installed.
This doesnât resolve the issue, I have Voicemeeter and even with +12 db on Bass (max) there is still no bass and at +12 db the speakers are vibrating to the point that there is speaker distortion present. Sure, if I cup my fâing hands around the DMAS and my ears there is bass (gee, this is such a great suggestion! I can just fâing play anything like this perfectly!) but this is such a ridiculous proposition that it doesnât even need further mention.
Putting the KDMAS cushions on the DMAS and KDMAS still sounds better, with less distortion because of the closed speaker back design.
DMAS was rushed. Proper DMAS could be accomplished if one could tilt the speaker arms closer to ones ears like Index / G2 / VP2 speaker arms. But thatâs beyond the ability of genius Pimax engineers who simply retained KDMAS speaker arms as the solution.
Iâm seriously disappointed that these were even released in this state. Iâm out $100 because of Pimaxâ incompetence. Like this isnât fâing rocket science. The problem is the speakers are too far from the ears to be of open ear design. We are literally talking about a flimsy $2.00 plastic hinge that needs to be placed where the speakers screw into the headstrap. See: Vive Pro 2 speaker arms. See: Index and Reverb G2 speaker arms.
That everyone here who has tried the DMAS and finds the lack of bass and mids rendering the solution unusable means that Pimax engineers had to have similarly come to the same conclusion but released this garbage anyway. That we cannot get a refund is unacceptable and someone ought to be fired over this. Whomever made the decision to release the DMAS in this state deserves to be fired. Full stop.
Pimax, you made an unacceptable product, allow us to return it to maintain good faith.
my problem was no or bad audio coming out unless the right earpiece was mounted upside down â but even that wasnt consistent. lots of sound/sound quality issues (though not the high pitch noise people here are complaining about) . sounds great now , wish there was more bass after using the kdmas for so long but iâve gotten used to it now.
See my post to vulcan. GrodenVR has already created a solution that should work. Originslly for the Kdmas.
Amp wise there are some usb powered amps on Amazon. For under $20 cad.
Here is link to a topic where I had bought some bmr speakers ti experiment with. But have yet to get back to playing with them. Here is the link for 1 amp there.
I too have the high pitched sound Timo.H1 and Gsmith described. It appears as soon as the HMD is powered up, and it isnt affected by volume setting. I contacted Pimax support, hope they can help.
Apart from that, I am actually very satisfied with the DMAS. The highs and mids are pretty good, bass could be better, but its nowhere as bad as some described it in this thread.
I play with a Volume setting between 40 and 50%, so loudness is also good with my DMAS.
Now I only need to get rid of that soundâŚ
In the thread I linked to you earlier if you goto first post. Checkout the reddit link. Iirc the op on reddit talked about using some wool or batting of some sort to improve bass.
First try the audio was low, went in to windows and maxed it out and now the volume is fine, think the audio is good, better then DAS, bass is so so, if you cup them it is better.
And dont get why not Pimax add a driver that say Pimax DMAS or something like that and then mic Pimax mic or something, also add audio settings in pitools/experince
