I understand.
Can get on ebay: https://www.ebay.co.uk/itm/313627982462?hash=item4905af3a7e:g:kCQAAOSwgHVhC8NJ
Try Ebay india or Amazon?
Do you really think I didn’t try those eBay India stopped their operations in India longtime back and amazon is good for other things here not like these type.
Thanks for enlightening me.
Sorry - here is the link to the 30mm front direct –
https://cdn.thingiverse.com/assets/2a/68/06/89/63/8KX_Snorkle_30mmFt.stl
Don’t exceed 5 volts with most of these fans, they don’t do well.
@avengertj I found an extra USB cable of old phone charger so I just cut it but seem it contains 4 wires Black, White, Red, and Green, and Fan has 2 wires Red and Black…should I just need to connect those 2 wires to the fans Red and black? or Do I need another USB cable which has 2 wires? Attached is a photo below for reference
Also got this power bank below which is really tiny like credit card size and support 5V output as well
Power bank is great!
Just try to see if it works.
Red to red black to black.
Also so you might wanna try some cable trunking! https://www.amazon.co.uk/Corrugated-Protection-Flexible-Tubing-Trunking/dp/B084RFW8QX
Keeps your wires neat and tidy.
https://www.amazon.co.uk/Alex-Tech-10ft-Protector-Sleeving/dp/B07FW3GTXB
Do you think the cable of this product below can help to manage fan speed, Actually Long time back I bought a few tripods for my base stations and those come with these lights but I don’t use them so maybe I can just cut that light from cable and use that controller on it to manage fan speed…Do you think it’s a good idea?
Looks good to me!
The only way to find out is to try.
Don’t cut the usb side,cut the other side!
Yes, I am going to try it.
Wow, amazing, it worked and perfectly managing the fan speed along with the turn on/off button. Now I think no need to wait for that imported cable. unnecessarily wasted $30 on that imported one which still has months to arrive, I wish I got this idea earlier.
Now the cable wrap like this below could perfectly match it with Pimax 8K X, Will update once I done with whole setup, neat and clean
I’m so proud that you haven’t given up!
Can’t wait to see the finished 8kx mod fan by,Tadnyarahul
All thanks to @Sidekick1 who got this thought of Fan mod and so this is becoming possible for all of us. He is such a great and helpful person, he even provided a 30mm file also on request.
But a good lesson learned this time, never to hurry in buying things because many things could be found inside our home and you can just use it. Those two Tripods which I bought for my Base stations provided me two things, A nice cable and now the phone holder which also I never used so I just modify it in a way so it can fit nicely on Pimax 8K X just like it is one of the provided part of 8K X and there I will place my tiny power bank once it will arrive tomorrow.
@avengertj @tadnyarahul Have both of you received your PU leather comfort kit face foam yet?
I purchased this PU leather face foam from immersive display. I haven’t really tested out yet, I briefly tried it and it’s okay.
My both order are still in transit, Btw. What is the thickness of this one PU leather face foam? I really want my eyes to get away from the lens as I feel more comfortable that way so I feel the thicker one will correctly suites me, Currently with this 8K X stock foam my eyelashes touch the lens and it really disturbs me.
@tadnyarahul According the Pimax listing it’s 15mm.
I completed a few races today and the face foam is pretty good. It’s currently winter here so I’ll see how it goes in the summer.
@avengertj @Sidekick1 Done
My Pimax Facial Foam Replacement has arrived in my country.
I’ll let you know when it gets delivered!
