Isn’t that what you use to make a William Shatner sandwich?
Besides the bread, all you need is a big ham.
on the contrary, thin face pad creates more issues like blurriness and loss of focus, completely destroying sweet spot and making it similar to vive
when they finish 8kx i will demand for a cushion set or at least a thicker pad instead of currently used, cause it simply sux and annoys much more than everything else
At first it seemed blurry but then pulling the headset away from my eyes just a few mm fixed that problem.
this is it
the difference between 5k and 8k could be in headstrap, less pressure makes more distance between eyes and lenses, it helps, but feels not always comfortable
yes! that is him. lol
Kevin’s awesome. Possibly the best decision Pimax has made so far. He’s a backer and always answers questions with a calculated response. Also worked for NASA for frick sake
Yes the thin face pad are a problem. I had to pull the headset away from my face just a few millimeters just to get the sweet spot and remove distortion. I also think IPD should be 60-80 millimeters across the board for all VR headsets.
Why did the 8k seems to have a wider FOV than the 5k+ ? @Heliosurge
I think I saw Kevin ended a sentence with “Be advised”
They got him.
Thanks for the tip. I nearly missed that
Scroll down https://www.studioformcreative.com/
Indeed & as we know pimax has stated they wanted to hire from the community. Kevin’s experience & skills are going to help pimax. As a result we will have imho a perfect blend of eastern & western business harmony.
This clearly demonstrates the teams resolve as being fellow enthusiasts to provide the best overall experience.
Difficult to say. Though perhaps the higher end resolution may give a perveived wider FoV. To compare might need a measured experience. To compare.
Though another difference could also be how tight/compressed the face foam makes the eye to lems distance. (Doc-ok has a document on fov differences of eye to lens distance)
if only the headsets were as air-tight as those space shuttles
For all we know he was a nasa janitor
Being a janitor myself I don’t think he looks like a guy that sweeps floors 8 hours a day. Definitely more of a desk guy methinks. Certainly talks like an engineer. He’s been good for pimax so far.
What is the filter? 202020
If you look at your video cables some have a plastic cylinder on them near the connectors. These filter out emi/rf intetference.
Here is the link
Sims are what VR is meant for. just my opinion lool. Cant wait to try out project cars and assetto corsa
Sweet. Thanks! My 5k+ is set to arrive on Tuesday. Anticipating any possible obstacles. Do you know which power adapter specs is needed if sent with a euro/Asian power supply? (I’m asking you cause I assume you know lol) Will this one work: SAUNORCH Universal International Travel Power Adapter W/Smart High Speed 2.4A 4xUSB Wall Charger, European Adapter, Worldwide AC Outlet Plugs Adapters for Europe, UK, US, AU, Asia-Blue https://www.amazon.com/dp/B078M32R41/ref=cm_sw_r_cp_api_i_br4qCb2Q71CP8
Ths specs on the psu is 12v 2amps. Size of tip not sure but think the thread where @park has a link for a wall psu as well.
Cool thanks 20202020
