I was able to make the aim controller on the pc, wifi.
I have used the method used to make wireless the Hardlight VR Haptic Suit
You can find it in the description of this video:
Awesome stuff Marco!
Thanks! Just implementing someone’s else idea on another usb device
I think that we could make any usb device wireless using this method
What router did you use? The link in Rob’s video leads to a ‘Page not found’.
GL.iNET GL-MT300N-V2 Mini Travel Router, Repeater Bridge, 300Mbps
Is it tracking in 6dof?
or are you just emulating a gamepad?
you might be able to use psmove service to track it as a vive wand. or attach a vive tracker to it
It is for using in regular pc gaming, not in steamvr.
hmmm…why though? do you even aim bro?
Yes. The aim works and it can be used for pc gaming and for ps and xbox gaming , for any game, psvr and not psvr too, no matter if not originally compatible with the psaim controller. This is the point. Break the linitations inposed by the psaim controller/software by ps
I’d like to try this … do you have any blog somewhere with your setup/tutorial?
or even if you can post in the OP
with a step by atep.
I get the videos insteuction about turning the router in to a VHere wireless usb hub.
but im guedsing theres more to it.
I actually bought that same mini router last year but never got around to using it.
