Hello @PimaxQuorra why cant i reply at the new pimax play 2.0 closed-beta ?
Hi I had same needed to be granted access by pimax , they will answer you if you tag an admin in pimax discord
I’ve added you to the group, and you should be able to leave a comment now.
Hey Calvin, I also have this same difficulty. thanks.
Hi Calvin, please add me to the group so I can add my comment to the closed beta.
Thanks in advance
Heiko
I also can’t reply in the pimax thread
Can you link me a post where you are trying to reply?
The Pimax Play 2.0 thread
Hey, how are you. I wanted to access the beta but I couldn’t post there too. Please add me if you can. TIA.
You should able to leave a comment on the post now.
I cannot reply in any of the piplay 2.0 threads but can view them.
Permission granted.
@PimaxQuorra hey i have the Super UW, can I please test the new software please? i currently only get 122 HFOV so would like to try the new profile to see if that helps
Please check the DM.
I dont see my dm from you?
I can not reply to the beta invitation
Permission granted.
Same for me, I am also not able to reply to the pimax play post… ![]()
