White screen flash?!
Hello there. My headset has a weird issue (since purchase), it has white flashes appearing while playing different games. Looks pretty much like a photocamera flash, not to bright to blind but annoys a bit.
Do you guys have same issue with your headset or is my defect?
p.s. using pimax mod with last firmware and stable version piplay.
Its actually a “feature” it is the demisters working. There are fine wires in the lenses. You get a flash and they heat up (you can see them for a moment).
Is it a good feature ? Well that’s to be decided but it’s not broken. That’s pimax.
It’s fine then, just need to be sure its not a defect :slight_smile: Thank you.
p.s. actually yes, its a good feature. I’ve tryed vive and oculus before and i’m sure they were misted time to time, but i never had this with my pimax, now i know why >)
I don’t mine it either, some people have thrown a real hissy fit about it. Once it kicks in and the lenses heat up, I think it has an effect. (Mine will steam up if the head set is cold).
I have vive and I gotta swipe the lens every 30 mins or so. I tried today Pixma and oh dear no swiping. Lens is clean and sharp. They did something great here!
