**USB 3.0 Eye Tracking Module Setup ** For All Pimax Headsets
Special Note: We are developing a comprehensive eye tracking module guide that answers ALL known questions and should have that ready for download within a few days. We also have new versions of the software as a high priority for the two teams who are working on this.
Installation Steps:
1.Use a USB 3.0 compatible data cable and insert it into the USB-C port located on the side port of your Eye Tracking Module and the USB port into a USB 3.0 or better port on your PC as shown below.
Follow these steps to TEST your Eye Tracking Module:
To test if the Eye Tracking module is operating in USB 3.0 mode just follow these steps:
(please exit all eye tracking software like Pitool before performing this test)
2.Open AMCAP and select the drop-down menu called “Options” as shown in the photo below.
3.Select 120 frame rate and 640*480 resolution.
4.If 118 FPS appears in the lower left corner this means that the eye tracking is working in USB3.0 mode.
Troubleshooting: If 118 FPS does not appear please make certain you are connected to a USB 3.0 compatible port on your PC and using a high quality USB 3.0 cable.
Additional Notes:
Here are some cables that can be used for the Eye Tracking module
(preliminary list)
Currently Tested Cables:
31 more dollars to have a decent eye tracking with less delay!!! Why do we have to pay for this? I think this is not fair.
Pimax should have given more information about this issue before people bought the eye tracker.
How do we know this is going to work better? Is there any people who have tried?
from numbers 30Hz might be good enough when the software (rendering pipeline) can translate that refresh rate and all works as “planned”
reference would be a nvidia pdf file about eye tracking that assumes 30-70ms latency as ok
it might be also advisable to use a blurring filter for the rendered picture when rendering in lower resolution to minimize distracting effects (pimax dev’s ?) - default steam home environment look horrible because of missing blurring filter when using FFR/DFR and it did not seem to work properly with the new (higher) rate - all the picture was low res with some flickering (with my 5k+)
the method above is ok to check for proper usb3 connection and could also be checked when running the calibration and checking the UserSDK.log for
EyeTracking camera = 0, rate = 118
slow eyeType = 1, idx = 1, rate = 118, average time = 1599, has fd = 0, no fd = 118
latest amcap-9-23-build-300-6 did not work on my win10 system (1909) but a older exe file provided by 7invensun worked flawless (测帧Amcap_.exe - Google Drive), when in shows 120Hz when choosing 640x480 then its in optimal configuration
it seems to be sensitive to what port and cable is used, a “normal” 3m usb-c cable only reached 30Hz @640x480 but a high quality (usb 3.1 gen2, 1.5m) cable did it on my system, 120Hz (or 118Hz in UserSDK.log) @640x480
i was not able to use this “external” connected configuration in steamvr (with pitools) yet but i will try if it does after a reboot
edit: on 5k+ the eye tracking module uses the “forward” facing usb connector (upper usb port on 5k+) when connected, i had to add a mechanical “spacer” between headset and module to prevent that and to use the side usb port with usb3
edit2: a spacer is not enough, got a ground loop because of still existing connection, used the plastic cap that came with the unit to isolate the usb-c plug of the unit
also the “external” connected eye tracking worked fine with pitool and steam vr after rebooting and recalibrating, now i will have to wait for a longer cable
I doubt it. A value of 50Hz is considered low, Tobii has 250Hz, for example. In addition, it will also affect the FOV, as the eye will move faster to cover more distance in the same time.
To be fair, Tobii and other eyetrackers are designed to follow Microsaccades, which isn’t needed for this kind of use-case. Nonetheless 30Hz seems really slow for tracking eye movement.
One of the members of a group I belong to managed to get the eye tracking to work, but complains about a rather slow response.
I’ve left him a message to comment on it.
Of course I’ll test it, when it arrives.
To confirm, do we need a 5GBps cable (USB-A 3.0 to USB-C) which Pimax Quorrra linked above which is a 5Gbps Oculus link cable, or is it best to try and source a 10 Gbps cable (USB-A 3.1 to USB-C)?
I tried to find what you suggested (USB-A 3.1) and wasn’t successful in anything over 2m.
a 3.1 gen2 cable needs to have batter quality then 3.1 gen 1 (aka 3.0), it was simply the best cable i had around and a “simple” (cheap) 3m usb-c cable did not work with full speed, same for a 2m 3.0 cable
i stopped messing around after the 4th cable and just used the cable that worked for testing
i hope the 8m quest bundle does work as promised (quest does need 5Gbit to work properly)
Is there a reason why the 8kx USB-C port wasn’t made with 3.0? I feel people who bought the 8kx, did so as they didn’t want to compromise on quality.
An additional cable to the PC is not ideal, we’re wanting to reduce those not increase them.
EDIT: seeing @anon57422158’s reply on the ET Hz thread. Does it mean the 8kx does have the usb 3 but it’s not working due a driver issue? But even when fixed it will not be as good as a direct PC connection?
If these are correct, how close will it get to the performance of the direct PC connection when driver issues are resolved?
The cable should be included as the Headsets are not able to run the ET as advertised. Due to 5k and 8k not being built to Advertised specs from the KS(stated usb 3 interface, but released as usb 2 only). And the 8kX usb 3 port not performing either as advertised.
This essentially makes the modular modules wonky as the headsets cannot properly support modules; save things like the cancelled fans.
