If You own a Pimax 5K(*) or an 8K(X) and use Valve Lighthouse V2 and do not have a current Valve Index headset, I wonder how to update or downgrade the lighthouses.
There are some hints in some threads but I did not see any real solution so far
If you own an HTC Vive, You are able to update LH1, but not LH2 (Only Vive Pro allows, see Vive Homepage)
As others already stated, Steam ignores the update requirement, and Pimax does neither provide a solution
I wonder how to update LH2, if Steam system report tells You to update from 3002 to 3008
** - But SteamVR client tricks You and fakes a green light?**
(“Aktuell” means “current version”, it´s a German client system)
I would like to update and perhaps try to get rid of the “jitterbug” or if just reduced and stabilized tracking, I would appreciate.
It seems, there is a way to update manually, but it seems, risky, too, as some failed and bricked their LH2.
If You look at Steam discussions, there is no solution at all.
Which is the current firmware and where to download it and how to flash it manually?
I am not eager to brick my Lighthouses.
