that one is at 100%,i wish i had that mic boost slider,but i have only the mic gain slider and that one is at 100%
This is beginning to sound like a hardware issue.
i only need that mic boost slider but it isnt there,its strangeā¦
I have mic sound but it needs to be louder
I still recommend you to upgrade your motherboard sound drivers⦠try that atleast.
Iām reading conflicting information of does a usb sound device need a soundcard to work. It apparently depends on the device.
I think it does, if itās kind of pass-thru device without any actual sound circuitry.
I found this & might help
Also this from ms forum
@anon74848233 it might be an idea to see if the team can implement a custom mic driver as microsoft doesnāt seem to be making fixing their generic usb mic driver a priority.
i tried it but doesnt work a pittyā¦
i had this issue as well but its gone after i boosted the setting in windows microphone properties.
but i dont have that boost settings? only the gain sliderā¦
i dont have that booster slider either i mean the vol slider was on like 75% but on 100 its fine for me.
people say the volume is on the low side when i play contractors online,
and if you look at the mic gain levels when speaking it is indeed very lowā¦
I wonder if a registry value might force boost the mic level or a setup file in steam?
Alternatively might be able to set boost slider with both USB mic & standatd mic plugged in. (Need to test)
i wish there was an ini file to increase the AGC(auto gain control)
i dont have a solution yet,am i the only one?
still no solution found,a pitty
Received,We will discuss about this
I think a mic boost option in the pitool app is a must,because some people like me dont have that option in windows 10.
