Something changed in the ability to add asset photo in Piplay 2.0 it's broken
We use to be able to point to the correct photos to fix this issue, but in the section in the .json file doesn’t even show in the beta 2.0 software. Works find in the latest old version.
Okay. I’ll report back to the devs.
  1. Open Windows File Explorer and enter %APPDATA%\Pimax\manifest, then press Enter。
  2. Locate the local.xxx.json file and modify the icon field.
  3. After that, restart the client.
Try this @Tatsukoa
No—the location has already been changed to the one I shared earlier.
However, if you’re using Pimax Play v1.43.x, the .json file will still be available.
Thanks, also are we able to set custom images from our desktop. Let’s say for star citizen since it doesn’t have a steam header jpg link?
Thank you! That worked!
Glad it worked.
