Can someone any one look at this and tell me what’s wrong Pimax said they see nothing yet every ew minutes it loses tracking and the 2.0 bas stations both work when used individually https://drive.google.com/file/d/1Cnjelg5_EBaZE478pfl6xbRiBahdML5N/view?usp=sharing
I sometimes have this problem!
Try putting your base stations closer to you or move closer to the stations!
If this doesn’t work then it’s your graphics card!
Try turning the resolution down!
Also it could be your cable! Check that it’s free off any snags!
Hi rephil:
Please check if there are lots of reflective object around,like glasses, smooth wooden floor? If was, you may try to cover them and recheck iJitters problem.
Is anything logged in SteamVR Web console? Does it happen with other games? Does it happen with 3-DOF tracking only?
Got that answer from FB and it was a reflection issue covered up a gloss black all file holder that was causing issue thanks
