Now to the issues, maybe someone knows a fix or two.
Issue 1: 2 pixels are always white. Its not very noticable in a game but in dark scenes it is.
Issue 2: my screen often shows tiny pixels going bright, it looks kinda like when u see stars caused by eye strain.
Issue 3: i can notice the warping/distortion on the outer edges very much
Issue 3 might get fixed via patches, i dont know.
Issue 2 i dont always have, but quite often
Issue 1 doesnt really bother me that much, since i mostly dont notice it.
As far as the distortion goes, the posts that I’ve been seeing indicate that you have to reposition the headset. I think the distortion is moving the headset either closer or farther from your eyes (as opposed to the ipd settings). In other words, you may need a different thickness of facepad.
Congratulations on your new headset!
yeah ive read about that but i always seem to notice it, no matter how close or far it is away. and any closer would make my eyeballs touch the lense xD
My only other idea would be to ask which of the FOV settings are you using? On the “wide”, the distortion is to be expected (some, anyway) vs on normal it should be ok and narrow should be non-existent, I think.
Other people have commented the distortion is less if you move the headset higher on your face and/or move it away or closer - if you are already as close as you can be try vertical and then try spacing it off too even.
yo, i had to pull it further away then its all gone so you were right man.
thanks! now i need to tell customer support to send me a thicker facecover. … meh
