Seeking Recommendations: Knuckle Grips for Stock Crystal Light Controllers
Hello everyone,
I’m excited to say I’ve just ordered a Crystal Light and I’m trying to get my accessories sorted out before it arrives. My top priority is finding a good set of knuckle-style grips or straps for the stock controllers.
From my initial research, it seems that official off-the-shelf options are very limited. The most common recommendation I’ve found so far is to 3D print a set using a community-designed file.
I have a couple of questions for the community:
For those of you who have 3D printed grips, is there a specific model or file from a site like Printables that is considered the “gold standard” for comfort and security?
Has anyone had long-term success modifying a grip made for another controller (like the HP Reverb G2) to fit the Crystal controllers?
I’m open to any and all solutions and would appreciate any links, photos, or advice you can share. My long-term plan is to eventually upgrade to a Lighthouse setup, but I want to make the stock controllers as comfortable as possible in the meantime.
Thanks in advance for the help!
The pimax inside out controllers are closest to oculus quest 2 controllers. I use silicon grip for it, had to cut out a little to free thumbstick and green led on controllers, EDIT: and bottom for charging:
https://www.amazon.de/-/en/gp/aw/d/B0CG2TVXK6?ref=ppx_pop_mob_b_asin_title&th=1
PS: I am not sure if you were asking for that, grip with strap…
Yes it is and I’ve considered it as well, just wondering if anyone else found a different option instead
You may want to check out this: Pimax | Printables.com
