Requesting ability to adjust mOLED duty cycle
When playing sim racing games where you stare forward most of the time this issue not a problem (at all) But when playing games like Forefront or any fast pace game where you have to look around the mOLED seems to have a sort of “motion blur” even with solid 90fps. I have seen this as a problem before on the QLED but sadly it also is a thing on the mOLED. At the end of the day though pixel response has nothing to do with it. Micro-OLED switches in microseconds. What matters is how long each frame is lit, and that’s a firmware decision.
I think the trade off that was made is that short illumination costs brightness. Micro-OLED is already brightness-constrained relative to LCD, so running a genuinely short duty cycle on these Sony panels means a dim image. Since Pimax is targeting a bright HDR-looking picture, they extend the illumination window instead, and pay for it in motion clarity. If Pimax made that call on the micro-OLED module, the blur is baked into the firmware and there is no setting that fixes it.
My request:
Find out if Pimax Play exposes anything like “low persistence,” MPRT, or a brightness mode on the micro-OLED module specifically or if this is something that would be possible with sboys or mbucchia.
Did you really need to use AI to write this?
Do you know if we have access to those options?
Is this “motion blur” issue visible on Dream Air SE only, or also for the Dream Air?
