I have a quick question to see if anyone else is seeing this when playing DCS?
if i move my head to look out the cockpit and back, there seems to be a quick blurry sec then into focus when i stop moving. Some say this might be DLSS or Frame pacing . I have tried DLAA, MSAA, DLSS, NONE but i still get the small second the view has to focus.
my question is, do any of you see the same thing? I’m trying to figure out if this is a DCS, headset or setting thing.
thanks
do you have Eye tracking and quad views enabled? Could just be that it’s trying to catch up or match up to your gaze
blackhawk163 so i appreciate your suggestions, but this did not answer my question. Are you saying you do not experience this at all? no focus delay at all?
if no one is having this issue, then that says the cause is in my setup. otherwise i am chasing a ghost. And yes, i have have tried eye tracking and Quads on/off with the same results.
before i spend more days and hour trying to fix this, i want to make sure its not just a artifact of DCS.
Nope. Just tested this on the p51 quick mission dogfight vs Dora. Kept snapping my head outside then inside. No focus issue. No artifacts. Instant and sharp.
Interesting. . You still on version 1.43 and not on 2.0 in the Pimax app?
i noticed in the Desktop mode i could resize the desktop and when i snapped my head to look at the clock in the lower corner, Yep it was showing a focus issue.
So that means its not from DCS, but maybe version 2.0 in the app.
No I’m running all the latest software that just dropped.
I’m also running the latest sboys3 driver and VectorXr
ok i am not runing these, PimaxXR and just play 2.0
maybe i should try these, i know about Sboys but were do i get the other?
