I am using in ear headphones with my Pimax 8k X. I really prefer in ear headphones as they „isolate“ me from my surrounding.
The only strange thing is that i do need to turn down the overall volume in Windows to 5-8 (out of 100 max). While using in parallel Discord it becomes sometimes quite difficult to balance the game sound and the voice chat.
Am I the only one having these issues or is this „normal“ using the 8K X together with in ear headphones? I would expect to have the windows loudness level more at 30-40 in a „normal“ level.
Is anyone having the same experience or are you using your Pimax at loudness level more in the 30-40s?
And could someone please try this with his Pimax 8K X?
I personally experienced the 8KX with the KDMAS, and the overall volume is Windows is set around 45-50.
But while using the Discord and in game, I still need to configure the sounds, to ensure my teammate’s voice chat and game sound are balanced.
ATM, never try the 8KX with in ear headphones, so I couldn’t share much on this. You may to configure the sounds setting in Discord and Games to find the balance.
strange. Maybe someone else can please check and write down their volumes.
I am not searching for complaints but rather a solution that i might not have found so far.
Even tried to switch between different In-Ear Headphones but the result is always the same. Maybe I am missing some kind of “activatet” volume boost in Windows or the Pimax settings / software? Yesterday I needed to lower the volume even to 4 and keep “Space Pirate Trainer” at volume 1. Sadly the game does not support in-game sound level adjustments.
The SMAS from the headset is working fine but as stated i prefer the In-Ear solution.
Would be nice if some more Pimax users can just shortly note their used “volume” setting and type of headphones.
Maybe like this:
Headphone Type: Various In-Ear Headhones Sound Volume: 5 (out of max 100)
