Private Beta Build v0.39 - More than 50 Hand models/skins to chose from for Hand-Tracking! :)
IMPORTANT NOTES:
Use PiTool version 1.0.1.264 Beta (or later). PVRHome beta updates do NOT include PiTool anymore, because its not needed anymore.
Just get latest PiTool 1.0.1.264 here: Gambling Apps Philippines - find best best betting and casino apps
And simply replace the content of PVRHome folder (read how-to below)
Download Pimax VR Experience
Beta v0.39:
Beta v0.39 Release Notes:
  1. More than 50 Hand models added for Hand-Tracking interactioon, both male, female, robot arms etc… :slight_smile: Well, its maybe 10 models and 50+ different skins/materials in total. Had some real head-ache to make the female hand & arm models to work (as they were deprecated and needed to connect new scripts and bind the whole thing with nodes/wrists/fingers etc), but I made it to work eventually! The models/skins are listed on point 4 below.
  2. Added drop-down list for selecting Hand Models in Customize UI page. Arrows can also be used to browse through the models, but a dropdown might be handy as we now have over 50 models to chose from :slight_smile:
  3. Fixed a few minor UI bugs…
  4. Hand Tracking Hand models added:
  • Male Hands Human 1
  • Male Hands Human 1 + Arms
  • Male Hands Human 2
  • Male Hands Human 2 + Arms
  • Male Hands Human 3
  • Male Hands Human 3 + Arms
  • Male Hands Human 4
  • Male Hands Human 4 + Arms
  • Male Hands Human 5
  • Male Hands Human 6
  • Male Hands Human 6 + Arms
  • Male Hands Human 7
  • Male Hands Human 7 + Arms
  • Male Hands Human 8
  • Male Hands Human 8 + Arms
  • Male Hands Alien
  • Male Hands Pale
  • Male Hands Green
  • Male Hands Blue
  • Male Hands Metallic 1
  • Male Hands Metallic 2
  • Male Hands Glossy
  • Male Hands Glittery
  • Male Hands Cartoon
  • Male Hands Glow
  • Female Hands Human 1
  • Female Hands Human 1 + Arms
  • Female Hands Human 1 + Arms + Nails
  • Female Hands Human 2
  • Female Hands Human 2 + Arms
  • Female Hands Human 3
  • Female Hands Human 3 + Arms
  • Female Hands Human 3 + Arms + Nails
  • Female Hands Green
  • Female Hands Blue
  • Female Hands Metallic 1
  • Female Hands Metallic 2
  • Female Hands Glossy
  • Female Hands Glittery
  • Female Hands Alien
  • Female Hands Pale
  • Female Hands Ghost
  • Female Hands Cartoon
  • Female Hands Cartoon + Arms
  • Female Hands Glow
  • Robot Hands 1
  • Robot Hands & Arms 1
  • Robot Hands 2
  • Robot Hands & Arms 2
  • Robot Hands 3
  • LoPoly Hands
  • Capsule Hands
How to get started (IMPORTANT)
  1. Install the PiTool 1.0.1.264 (or later) here: Gambling Apps Philippines - find best best betting and casino apps
  2. Open PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
  3. Go to C:\Program Files\Pimax\PVRHome\ and remove all content inside the folder.
  4. Copy all content from this ZIP/RAR and paste it into C:\Program Files\Pimax\PVRHome\
  5. In PiTool, go to Settings → General and ENABLE/CHECK “Start Pimax VR Home” to start the Pimax VR Experience
Pimax VR Experience should now start in the background and inside your Pimax VR headset.
Check the Unity log file:
The log is created every time you exit the application.
So to be able to read the log, exit Pimax VR Experience first, by:
  • open PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
or
  • Click on the Quit button (bottom bar) in the Pimax VR Experience
The log file is called:
Player.log
The previously created log is (previous instance of the application running):
Player-prev.log
Game Appdata files & config
The program appdata files, user settings file, favorites etc that are used by VR Experience are located in:
*%APPDATA%/\LocalLow\Pimax\PVRHome\
User Settings profile:
%APPDATA%/\LocalLow\Pimax\PVRHome\userSettingsPVR.json
Other useful info
Game import-data profiles (SteamVR/VivePort/Revive/Imported) are located in:
%APPDATA%/\LocalLow\Pimax\PVRHome\GameImports\
AND:
Game import-data profiles (Oculus games only) are located in (temporary solution):
%APPDATA%/\Roaming\PiTool\manifest\
Game SETTINGS profiles (SteamVR/Oculus/VivePort/Imported) are located in:
%APPDATA%/\Roaming\PiTool\manifest\PiTool\
Favorites import-data profiles are located in:
%APPDATA%/\LocalLow\Pimax\PVRHome\Favorites\
SteamVR Optimization profiles for SteamVR/VivePort/Imported games are located in:
%APPDATA%/\LocalLow\Pimax\PVRHome\CustomSteamVRProfiles\
Thank you for helping out!
/ Martin, SweViver
