Private Beta Build v0.34 - Game Management & more!
IMPORTANT NOTES:
After installing the new PiToolSetup_1.0.2.071, you NEED to replace the content of folder C:\Program Files\Pimax\PVRHome\ with the content of the folder \PVRHome_v0.34\ Included in this ZIP/RAR file!!!
Bundled with NEW VERSION PiToolSetup_1.0.2.071. The PiTool is REQUIRED to be installed. Download link below: (same link, new folder PVRHome_Beta_v0.34). Available in compressed RAR and ZIP file:
Beta v0.34
Release Notes:
  1. New Feature: Game Management (Advanced page) added! Now you can EDIT games in all categories with fields below. Note: Editing game title will also automatically apply the changes to Settings profile, SteamVR Optimization profile and also for the same game in Favorites category.
  • Title (name)
  • Game Type (game/application for future categorizing)
  • Thumbnail (any jpg/png file supported)
  • Runtime (only editable for custom Imported games, to prevent breaking functionality)
  1. New feature: Delete any game from any category with two clicks (confirm popup) in Game Management, just like profiles. Delete game means also the connected Settings profile + SteamVR profile also gets deleted. And the game is deleted from Favorites of course.
  2. New feature: Thumbnail Preview added in Game Management (Edit game) + New Import page where you import new custom games. After selecting thumbnail image (with fileBrowser), the thumbnail is seen in a preview just below the input field.
  3. Quick link button to/from from Game Management and Game-view added! Edit any game quicker without searching for it. Enter Game Management at any time directly from the game-page, by clicking on the button in top-right corner. And go back to game again by simply clicking on the green shortcut.
  4. Fix: Fixed an issue we’ve had since forever in Profiles list-view and now also in Game Management list-view when the entire list sometimes jumped/glitched for a millisecond after refreshing. This was caused by an improper use of content size fitter, which I found a solution for.
  5. Fix: A few fileBrowser issues fixed. Now it definitely should work as expected when browsing your PC for files.
  6. Fix: A few improvements and bug fixed with listings of profiles and games. Not completely bug-free yet, but getting better for every day! :slight_smile:
How to get started (IMPORTANT)
  1. Install the included PiTool version (file PiToolSetup_1.0.2.071.exe)
  2. Open PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
  3. Go to C:\Program Files\Pimax\PVRHome\ and remove all content inside the folder.
  4. Copy all content from the \PVRHomev0.34\ folder provided in this RAR file, and paste it into C:\Program Files\Pimax\PVRHome\
  5. In PiTool, go to Settings → General and ENABLE/CHECK “Start Pimax VR Home”
Pimax VR Experience should now start in the background and inside your Pimax VR headset.
Check the Unity log file:
The log is created every time you exit the application.
So to be able to read the log, exit Pimax VR Experience first, by:
  • opening PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
    or
  • Click on the Quit button (bottom bar) in the Pimax VR Experience
The log file is called:
Player.log
The previously created log is (previous instance of the application running):
Player-prev.log
Game Appdata files & config
The program appdata files, user settings file, favorites etc that are used by VR Experience are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\
User Settings profile:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\userSettingsPVR.json
Other useful info
Game import-data profiles (SteamVR/VivePort/Revive/Imported) are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\GameImports\
AND:
Game import-data profiles (Oculus games only) are located in (temporary solution):
C:\Users*user*\AppData\Roaming\PiTool\manifest\
Game SETTINGS profiles (SteamVR/Oculus/VivePort/Imported) are located in:
C:\Users*user*\AppData\Roaming\PiTool\manifest\PiTool\
Favorites import-data profiles are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\Favorites\
SteamVR Optimization profiles for SteamVR/VivePort/Imported games are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\CustomSteamVRProfiles\
Thank you for helping out!
/ Martin, SweViver
