IMPORTANT NOTES:
After installing the new PiToolSetup_1.0.2.071, you NEED to replace the content of folder C:\Program Files\Pimax\PVRHome\ with the content of the folder \PVRHome_v0.32\ Included in this ZIP/RAR file!!!
Bundled with NEW VERSION PiToolSetup_1.0.2.071. The PiTool is REQUIRED to be installed. Download link below: (same link, new folder PVRHome_Beta_v0.32). Available in compressed RAR and ZIP file:
Beta v0.32
Release Notes:
IMPORTANT: Fixed Hand-position (offset) of both hands in Hand-Tracking mode. Hands should now be correctly positioned and angled using all Pimax UltraLeap devices. How does it work with standalone (old) Leap Motion devices? Please let me know!
Forward Rendering Mode: VR Experience is now (experimentally) using Unity “Forward rendering” mode (forward render pipeline) instead of Deferred Rendering mode that was previously used. This should slightly increase the performance and allow for Anti Aliasing. Please let me know!
Experimental: Anti Aliasing (MSAA x4) applied and used in VR Experience. This is supposed to remove some shimmering lines/text on lower resolution. Let me know IF it works and if it kills performance! Personally I can barely see any difference. Is it really working?
Fix: Laser pointer (VR controller mode) adjusted 4 degrees to be more correct and identically angled to SteamVR laser pointer.
Fix: A bug is fixed where Revive games did not allow to enable/disable or edit SteamVR profiles in game-view. This is now resolved.
Fix: A bug is fixed with Scroll-view in “Settings”. When clicking on shortcut button from game-view to see the Settings of specific profile, the “Settings” did not correctly scroll up to the top (and actually threw an error in log). This is now resolved and “Settings” should scroll to the top automatically when entered from shortcut-link on the Game-view page.
How to get started (IMPORTANT)
- Install the included PiTool version (file PiToolSetup_1.0.2.071.exe)
- Open PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
- Go to C:\Program Files\Pimax\PVRHome\ and remove all content inside the folder.
- Copy all content from the \PVRHomev0.32\ folder provided in this RAR file, and paste it into C:\Program Files\Pimax\PVRHome\
- In PiTool, go to Settings → General and ENABLE/CHECK “Start Pimax VR Home”
Pimax VR Experience should now start in the background and inside your Pimax VR headset.
Check the Unity log file:
The log is created every time you exit the application.
So to be able to read the log, exit Pimax VR Experience first, by:
- opening PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
or - Click on the Quit button (bottom bar) in the Pimax VR Experience
The log file is called:
Player.log
The previously created log is (previous instance of the application running):
Player-prev.log
Game Appdata files & config
The program appdata files, user settings file, favorites etc that are used by VR Experience are located in:
C:\Users\ user \AppData\LocalLow\Pimax\PVRHome\
User Settings profile:
C:\Users\ user \AppData\LocalLow\Pimax\PVRHome\userSettingsPVR.json
Other useful info
Game import-data profiles (SteamVR/VivePort/Revive) are located in:
C:\Users\ user \AppData\LocalLow\Pimax\PVRHome\GameImports\
AND:
Game import-data profiles (Oculus/Imported) are located in (temporary solution):
C:\Users\ user \AppData\Roaming\PiTool\manifest\
Game SETTINGS profiles (SteamVR/Oculus/VivePort/Imported) are located in:
C:\Users\ user \AppData\Roaming\PiTool\manifest\PiTool\
Favorites import-data profiles are located in:
C:\Users\ user \AppData\LocalLow\Pimax\PVRHome\Favorites\
SteamVR Optimization profiles for SteamVR/VivePort/Imported games are located in:
C:\Users\ user \AppData\LocalLow\Pimax\PVRHome\CustomSteamVRProfiles\
Thank you for helping out!
/ Martin, SweViver
