IMPORTANT NOTES:
After installing the new PiToolSetup_1.0.2.071, you NEED to replace the content of folder C:\Program Files\Pimax\PVRHome\ with the content of the folder \PVRHome_v0.31\ Included in this ZIP/RAR file!!!
Bundled with NEW VERSION PiToolSetup_1.0.2.071. The PiTool is REQUIRED to be installed. Download link below: (same link, new folder PVRHome_Beta_v0.31). Available in compressed RAR and ZIP file:
Beta v0.31
Release Notes:
New Feature: Added ability to adjust the XYZ position of the UI (move around the entire UI) by clicking and dragging an icon/button right next to the Pimax VR Experience banner. The UI canvas had to be slightly re-made to make this working, but it doesnt seem to brake any functionality with any other UI elements. Free movement is possible in X, Y and Z axis, working with both left and right controller (the active one that uses laser). The feature is currently NOT possible with hand-tracking yet, as its a little but more complicated, but Im working on it. In upcoming versions of VR Experience, the custom position will be saved in the user profile, but currently its not.
Fix: Solved a bug where hand-tracking pointers were rendered behind drop-down menus. Now they are properly rendered on top of drop-down menus.
Fix: Adjusted the hand-tracking click/scroll sensitivity, and should now make it slightly easier to click and scroll. Im currently working on adding sensitivity-sliders for personalized adjustments.
Fix: Removed haptic-feedback (vibration) from controllers upon clicks and hovering over buttons/items when Hand-Tracking mode is active.
Fix: Removed the non-working left hand popup which was accidentially visible in version Beta 0.30. This popup is no longer needed, as UI position movement now is made as described in point 1 above.
How to get started (IMPORTANT)
- Install the included PiTool version (file PiToolSetup_1.0.2.071.exe)
- Open PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
- Go to C:\Program Files\Pimax\PVRHome\ and remove all content inside the folder.
- Copy all content from the \PVRHomev0.31\ folder provided in this RAR file, and paste it into C:\Program Files\Pimax\PVRHome\
- In PiTool, go to Settings → General and ENABLE/CHECK “Start Pimax VR Home”
Pimax VR Experience should now start in the background and inside your Pimax VR headset.
Check the Unity log file:
The log is created every time you exit the application.
So to be able to read the log, exit Pimax VR Experience first, by:
- opening PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
or - Click on the Quit button (bottom bar) in the Pimax VR Experience
The log file is called:
Player.log
The previously created log is (previous instance of the application running):
Player-prev.log
Game Appdata files & config
The program appdata files, user settings file, favorites etc that are used by VR Experience are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\
User Settings profile:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\userSettingsPVR.json
Other useful info
Game import-data profiles (SteamVR/VivePort/Revive) are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\GameImports\
AND:
Game import-data profiles (Oculus/Imported) are located in (temporary solution):
C:\Users*user*\AppData\Roaming\PiTool\manifest\
Game SETTINGS profiles (SteamVR/Oculus/VivePort/Imported) are located in:
C:\Users*user*\AppData\Roaming\PiTool\manifest\PiTool\
Favorites import-data profiles are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\Favorites\
SteamVR Optimization profiles for SteamVR/VivePort/Imported games are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\CustomSteamVRProfiles\
Thank you for helping out!
/ Martin, SweViver
