IMPORTANT NOTES:
After installing the new PiToolSetup_1.0.2.071, you NEED to replace the content of folder C:\Program Files\Pimax\PVRHome\ with the content of the folder \PVRHome_v0.27\ Included in this ZIP/RAR file!!!
Bundled with NEW VERSION PiToolSetup_1.0.2.071. The PiTool is REQUIRED to be installed. Download link below: (same link, new folder PVRHome_Beta_v0.27). Available in compressed RAR and ZIP file:
Beta v0.27
Release Notes:
- HUGE UPDATE: UI Interaction with VR controllers almost completely re-written and all bugs and issues should be 99.9% fixed:
- No more scrolling glitches or bugs when dragging pages/menus
- Scrolling among game lists (gallery/list view) now works as expected and more “natural”
- Scrolling inside drop-down menus now fully working (not only with scrollbars, but also by dragging with pointer)
- Dragging game thumbnails or items doesnt result in accidentially clicking into game page (made my own new script with proper algorithms that determinates if a click should be made, or if user is scrolling/dragging only)
- Dragging scrollbars doesnt jump around and behave glitchy anymore when pointer leaves the scrollbar
- Clicking and dragging empty space on any page behaves normally, and scrolling by dragging empty space works properly
- Scrolling speed corrected and now faster (will soon add an option for scroll speed adjustment).
- If clicking an object/button, holding and dragging away and then releasing the trigger will now NOT result in improper click or abnormal behaviour
- New UI interaction should now be easier to implement with upcoming hand-tracking+mouse interaction that Im already working on!
Adjusted the game thumbnail view, so when thumbnails are not being pressed or pointer-hover, they are more vivid and looks slightly better overall. Enlargement of thumbails upon pointer-hover is slightly increased now (a few pixels), which I think looks better.
Fixed an ugly glitch with the virtual-keyboard (in Create New Offline Profile menu) when using the dark theme. Keys are now NOT turning blue anymore when pressed down/active.
Minor general UI improvements and some small issues corrected along the way…
How to get started (IMPORTANT)
- Install the included PiTool version (file PiToolSetup_1.0.2.071.exe)
- Open PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
- Go to C:\Program Files\Pimax\PVRHome\ and remove all content inside the folder.
- Copy all content from the \PVRHome folder provided in this RAR file, and paste it into C:\Program Files\Pimax\PVRHome\
- In PiTool, go to Settings → General and ENABLE/CHECK “Start Pimax VR Home”
Pimax VR Experience should now start in the background and inside your Pimax VR headset.
Check the Unity log file:
The log is created every time you exit the application.
So to be able to read the log, exit Pimax VR Experience first, by:
- opening PiTool, go to Settings → General and DISABLE/UNCHECK “Start Pimax VR Home”
or - Click on the Quit button (bottom bar) in the Pimax VR Experience
The log file is called:
Player.log
The previously created log is (previous instance of the application running):
Player-prev.log
Game Appdata files & config
The program appdata files, user settings file, favorites etc that are used by VR Experience are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\
User Settings profile:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\userSettingsPVR.json
Other useful info
Game import-data profiles (SteamVR/Oculus/VivePort/Imported) are located in:
C:\Users*user*\AppData\Roaming\PiTool\manifest\
Game SETTINGS profiles (SteamVR/Oculus/VivePort/Imported) are located in:
C:\Users*user*\AppData\Roaming\PiTool\manifest\PiTool\
Favorites import-data profiles are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\Favorites\
SteamVR Optimization profiles for SteamVR/VivePort/Imported games are located in:
C:\Users*user*\AppData\LocalLow\Pimax\PVRHome\CustomSteamVRProfiles\
Thank you for helping out!
/ Martin, SweViver
