I think this.
Pimax 8K is a product.
PIMAX 8K X is another product
- Pimax is working on Pimax 8K. They are not working on Pimax 8K X because they are busy with Pimax 8K and ending Pimax 8K the project Pimax 8K X Improves some steps
Until here is OK.
What is thinking Pimax ? Pimax is thinking Pimax 8K X is HI END VR so upscaling is a bad idea
What are thinking users ? I want the best Vr experience so NO Upscaling is Good for me
In the middle there is real World. Pimax has nothing to show us otherwise they did not say
“X is for the next generation graphic card”, “supports 8K input, but require PC with at least GTX1080ti (still testing, may need 1080Ti SLI”, "or the next generation graphic card e.g.Nvidia Volta), CPU i7, and 16GB memory. "
Gtx 1080ti is not next generation graphic.
Gtx 1080ti sli test. When test are finished ?
Volta. No one knows if invidia is launching titan volta or 2080 volta. No one knows gaming performance
If TITAN VOLTA PRICE is 3000$ what we do ?
Has Pimax Volta ? No they has not
I am happy to have a pledge 8K X
I am happy Pimax has this project
But with upscaling i can sleep peacefully, without i am agitated
The solution is easy.
They take pimax 8k change hardware for two DP and unlock 2 X 3840 x 2160 resolution.
If user’s graphic hardware is powerfull there is no frame rate issue . He can enjoy full 8K VR otherwise
user set 2560 X 1440 in the game and the image is upscaled
Every issue with frame rate is gone away and user is happy.
What is the hell they discard this option ?
NOW Pimax 8K X does not exist .
I hope pimax change idea with upscaling
Please before writing in this topic tell us if you have a pledge Pimax 8K X
Thank you
