Thanks man
I hope so
it should be added to the list with the other links
Yes it’s 2.1.255.264, do you have al link to the previous firmware of the 8k+? I’m having the dim display problem
Unless it is 255 no. However pitool 260 in theory is suppose t9 correct the dim display issue.
If your part of the 8k+ Alpha you should have acs to precious alpha that has 110hz.
Hi jeroen
I get these light bars as well, ive sorta given up on 110hz,
I get light bars and a slight ghost on iracing, its like panel persistence.
So i guess 90hz is all ill get out the first gen 8k+.
I saw in another forum post that the Pimax engineers are investigating this issue. Hopefully, it will be fixed in the next PiTool update.
Same issue as with 259, pitool crashes on startup. I’ll revert to 258, again.
Thanks Dan, no i haven’t taken part in that, but i will pm Pimaxquorra if the have the previous firmware version
This is the link I used for 264
https://pitool.pimax.com/P2_RELEASE_M264_t20200508200801_r96b28a3.dfu
Whats happened in 259/260 with the resolution, do we now need to increase PiTools Render Quality or Steam SS, it seems to be rendering a much lower resolution.
Yeah I noticed this also. Loaded up Assetto Corsa and visuals were notably degraded. And since I’d done the same car and track combo the night before the difference was obvious.
Thank you very much !!!
@Heliosurge it would be very useful to add it to the releases links page.
What’s the easiest way to roll back to a previous version of the software? this drop in image quality is unacceptable.
First PiTools update in months and it’s major step back in image quality.
@anon57422158 whenever you do your next Pimax day, please share a software roadmap.
I did too, but I think the change may have been in SteamVR, based on when I noticed the difference.
I think you just need to bump the rendering res, either in SteamVR or PiTool.
Hi, related to PiTool 259 and 260B crashing on my computer here is the event log of one of the incidents:
Pitool 260B
The ucrtbase.dll is version 10.0.19041.1 (windows version 2004)
Pitool 259
The ucrtbase.dll is version 10.0.18362.815 (windows version 1909)
259 before upgrading to the newest Windows version, 260B after upgrade.
258 works without any problems.
Faulting application name: PiTool.exe, version: 0.0.0.0, time stamp: 0x5ed0b5ff
Faulting module name: ucrtbase.dll, version: 10.0.19041.1, time stamp: 0xbd1e2564
Exception code: 0xc0000409
Fault offset: 0x00000000000711e8
Faulting process id: 0x39dc
Faulting application start time: 0x01d637ad383313b2
Faulting application path: C:\Program Files\Pimax\Runtime\PiTool.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: 968ac4df-3aa0-4140-acad-e2504d7b4115
Faulting package full name:
Faulting package-relative application ID:
edit: Just realized I can start pitool it if the headset is not “on”, saw another post for 259 regarding this and tested it.
Got 1.5k+ h on PD2 (one of the greatest games of all times), did it mostly 2D though.
Do you have by chance any mods installed or forgot to remove them before starting PD2 in VR?
Lots of mods have issues after updates.
I needed to almost remove all of them for VR.
i am playing with no mods at all, and havent spent much if any time in the flat mode
I think that’s a really good idea. With plenty of screenshots too… ![]()
Maybe You should make it a Wiki post (to hopefully make it less “static”), link to it from the PiTool download site and make it part of the release procedure (if You have such a thing) to “check if PiTool documentation needs updating”… ![]()
I’ve been wanting to do a Wiki post for a long time, but You know, life/work/family… ![]()
my Pit00l just update to this version and again while everything looks good in pitool when I launch SteamVR it just says searching…
HMD just displays the pi logo and I’ve done room setup and other calibrations in pitool
Thanks a lot…!
