i sold them,because i have always had problems with the distortion.
Also i always cant get close enough to the lenses,and i had some crosseye feeling that felt not right.And i didnt like the colors(exept the colors of the xr offcourse)
Ps didnt test the brightness i think on pitool 244
So my upcoming pimax 8kx will be sold also very quikly i think…(i dont hope so ofcourse)
So far this thread seems to indicate this is a hopeful candidate for me to test with DCS World. Might finally be able to move from (IIRC?) PiTool .248 .
Why do you think 253 is faster? My testing of 259 puts it at the same FPS as 253. Yet 253 would have a spike every 1 and half second. So if this is the same performance as 259 then 253 is obsolete in my eyes
After a reboot my HLA issues went away. Although new issues have popped up since. I was playing Rachet NX and all the 2d objects (menu’s, etc) were missing (close and reopen didn’t fix it). Then I went into Saireto VR and the controllers and in game objects would disappear and reappear depending on the angle my head was at. At the extremes like usual but also in the middle of the frame. Very trippy.
I have run 253 in fruit ninja with reprojection turned off. Steamvr resolution reported at roughly 6000x* for both 253 and 259. Both ran at roughly the same timings expect 253 would have a spike every second or so. 253 was my go to pitool before as I always got 5-8 FPS more. But this version makes 253 obsolete by a large margin with all its updated features and very stable timings.
Edit… I’ll just say my testing was done with 259. But considering this is just a hotfix for the dim issue I see no reason this isn’t the same performance
I’ve installed this, have gone from 258 to 260. Should it have installed new firmware on an 8k+ or is that a separate download? I don’t see the 110hz option.
There´s too much ghosting in 144hz - it´s unusable.
In addition, the lack of 64hz checkbox remains (I prefer to use 64hz with Large/Normal FOV than 120hz with smarth smoothing limited to 110-125º FOV).
