Pimaxplay 2.03 seems cross eyed on crystal light
Have updated from 2.02 and immediately noticed something seemed off, I tried playing with ipd but had no effect. I’m not sure if cross eyed is the right description but I have to focus in a weird way (like looking at the old magic eye images). If I relax my eyes the image goes back to “not right” (can’t think of a better explanation)
Returning to 2.02 fixed it
On the default FoV mode?
yeah, and on wide fov.
thanks for reply.
I’ve swapped back to 2.03 and now I’m not sure if there’s anything different, something definitely felt “off” the first time but now I’m not so convinced.
I’ll stick with 2.03 for now and see if i notice any effects long term.
If no one else notices anything odd then it must just have been me.
Thanks
Okay.
I did receive similar feedback from one user on Reddit, mentioning that 2.0.3 caused a cross-eyed effect. However, I’ve also seen a few users mention that it’s working fine for them.
thanks for you time, I played for a couple of hours yesterday with no issue.
I’m not sure exactly what seemed wrong the first time I tried 2.03 but it seems fine now.
I can confirm this true, i have the same issue with my crystal light after updating to 2.03
What if you switch the FOV mode back to the default setting? Are you still experiencing the cross-eye issue?
(post deleted by author)
I have this too on my PCL: exactly the same as you describe.
