Pimax Play 2.0.3 i think has a issue with Quadviews?
Not sure if anyone else is seeing this. but on the Pimax Play 2.0.3 using QuadViews and playing DCS i am seeing the center image look brighter than the sides. this causes the sides to be a little darker and look like you are looking at a square in the headset.
I have test this with Quadview off and the issue is Quadview.
Note, that if i turn on/off the linear or alpha transition i still see the faint brighter square. This is seem more readily with the sky or lighter colors.
it seems that maybe the Quadview transition has some issue that need some work
has anyone else seen this?
settings : center 140%, transistion 45%, Horizonal 60%, vertical 60%. offset 0%.
quality set to 100%
i am running a RTX 5090 and ryzen 9.
Was SSAO disabled in DCS?
yes, i have tried everything and its still there. the only things to fix it is to make the center window so big your eyes don’t catch the sides.
I had an issue with my new Dream Air Slam and quadviews in MSFS 2024 with PP 2.0.3. Lots of scenery flashing and failing, turned QV off and the PC was jittery jumpy mouse and Keyboard after a reboot. I had to turn off eyetracking in PP to get my PC stable again.
Haven’t been back on the sim since but will tomorrow to see if it is still the same. If not I will uninstall PP again and try a reinstall but won’t try QV again.
I’ll bring this up with our team and the DCS QA team as well, to see if they have any insights.
Please keep me posted.
Thank you. I am aware it could be other things other than PP 2.0.3 however I haven’t been able to trace the issue further because I turned it off.
Thanks I will.
