Had lot’s of people asking through our webstore so just wanted to announce here on the forum that our Pimax MAS 300 gram counter weights are now back in stock
For anyone interested this set includes a pair of custom wraps each weighing 150gram (300/11Oz Total) Balancing the headset lifts the eye box off your face and helps keep your eyes in the sweet spot. These are handmade Items made by myself. Any questions please ask
The cable can stay in the original position. It can go up or down no problem. The counterweight wrap also gives you the option to drop the cable lower. Thanks
I highly recommend them too. My 8KX is noticeably more comfortable and I can wear it a lot longer with the counterweights. The weights themselves are of excellent quality (materials, stitching, packaging); better than I expected. Also, the original shipment was lost (by UPS) and my replacement was shipped courteously and promptly.
I don’t really notice the extra weight while actually using my 8KX, but the one (minor) downside of that weight is that the headset is a bit awkward to pick up and put on.
I don’t think that’s a problem with these counterweights.
I only play seated VR games and my computer is to the right, so I’ve routed the cable straight across the bottom of both weight packs. The cable does not bend sharply down at the end. It has a nice rounded curve.
Originally, I had the cable straight down the back, like most people. I only put the cable through the first loop, at a diagonal from the top-left corner to the bottom-right and then straight down. That arrangement reduces bending.
