Redesigned the client UI and reorganized features.
Grouped display, performance, rendering, interaction, and spatial settings into clearer categories.
Added a new default Dashboard showing headset connection status, device info, and frequently used settings.
2. Profiles
Added support for saving display, performance, and interaction settings as profiles.
Added custom names and descriptions for profiles.
Added profile import and export for backup and sharing.
The default profile now keeps your most recent settings changes.
3. PVRM (Flat-Screen VR Simulation)
Added support for displaying select traditional PC games in the headset.
Head movement can now control the in-game camera direction in compatible games, with an option to recenter the view.
Added Xbox controller support for game input
Note: PVRM does not convert flat games to native VR. Compatibility depends on each game’s camera controls and input methods.
4. System UI
Added the ability to save window position, size, and orientation.
Saved layouts are restored when System UI is closed and reopened within the same session
Known issue: layouts are not restored after the client is restarted.
5. General
Improved video recording.
Changed which settings are available in Open Ports mode.
Refined UI layouts, interaction details, and system messages.
6. Bug Fixes
Fixed FOV cropping not working correctly in some cases
Fixed the pinning feature in the Application Library
Fixed the login screen showing Chinese text in the English client
Fixed various UI display and localization issues
Fixed navigation links to help documentation and community pages
7. Update Rollout
This update will roll out gradually to all users over the next two weeks. The schedule may change based on performance and feedback
Thank you to everyone who participated in EVO testing and shared feedback. We will continue improving software stability, compatibility, and the overall user experience.
You could join the Discord server to get the download link.
I just installed clean this version of EVO. But I cannot log in, it always says: 'Login failed: invalid username or password.
I am using my email address, I don’t have a username (that i know). 15 minutes ago I was logged in with pimax play. This is a first for me, never seen this in any prior versions of PP or EVO.
Pimax Dream Air SLAM – I’ve installed this version.
I’d like the option to display the current resolution we’ve set for the Pimax to be brought back; I think it’s been removed. It’s a very useful feature.
Another issue is pinned windows. There’s the Utility performance window. I’d like it to stay pinned permanently once I’ve pinned it; as it is, I have to keep pinning it again and again.
Apart from that – CPU and GPU usage, current FPS, average FPS, and I can’t remember what else was there – I’d like it to show the current time and the current resolution set for the Pimax.
