26th Dec '23 :- Crystal HMD with
Radeon Sapphire Pulse 7900XTX using current AMD Adrenaline Driver.
For reference I am not new to VR. I got in early with Oculus DK2 followed by CV1 then Rift S, Reverb G2, Pimax 8KX and now my 6th VR headset, Crystal. It has been an exciting, exhilarating and hugely fun journey.
Recently upgraded from AMD4 5900X system with 3090 gpu and Pimax 8KX DMAS 2076 version to a new AMD5 system of 7800X3D & 7900XTX.
VR Gaming for me is 90% Sim Racing & 9% Flight in DCS or MSFS. For racing my time is lost in Assetto Corsa, AMS2, rFactor2 & Race Room Race Experience… ALL work brilliantly at exceptionally High frame rates. Rock solid image, zero issues. I have tested at 120hz & 72hz 100% no issues. My default is 90hz, the sweetspot for me.
I am gobsmacked by how great the 7900XTX performs in VR. AMD have obviously corrected the earlier VR driver issues. I was a little apprehensive going in but had read enough, mostly on reddit, to believe AMD had a handle on the vr issues and the flatscreen gaming performance benchmarks are impressive. Comparing the new performance & higher fps racing on this system, against the few benchmarks I can find from other sim racers on 4090’s, it looks like my 7900XTX is very close nipping at the heels and a little ahead in some cases. I am running high/ultra settings in AMS2 and the performance at 90hz / 90 fps is phenomenal. Very glad I took a chance on the 7900XTX.
I am still having a few issues with the Crystal (this is my 2nd unit), both having problems since day one a month ago. I think quality control is still a challenge for Pimax unfortunately. However once running correctly the quality of the image at 35ppd truly is amazing and such a leap that it is hard to go back to either 8kx or ReverbG2.
I did try some other VR games such as Red Matter 2, Arizona Sunshine 2, Half Life Alyx and they ran perfectly and looked stunning. Also tried No Mans Sky but that is hard to find the right graphical settings balance, need more time with that but it looked good.
Anyone on the fence about a Crystal with an AMD 7900XTX take another look as I have found the combo works perfectly and it really is amazing. Here in Australia the 4090 costs twice (or more) the 7900XTX so it is a no-brainer imho. But I am not into ray traced games, waste of horsepower imho, but for rasterized games and VR the 7900XTX is superb, an easy pick especially over a 4080, unless RT is your drug and/or money is no object.
The Crystal does not feel heavy or uncomfortable to me but I am used to the 8KX. I think it is comfortable though I wish the battery was optional plus the rubber power strap to the battery is a bit short for larger heads. I am still waiting on my Crystal Comfort Topstrap ordered 27th November so I hope that arrives soon as it looks to balance the headset better.
Overall I rate Crystal 9/10 and the best VR headset I have owned, for sims either racing or flight it is currently number one for me. The newer Varjo Aero and BigScreen are options other users will be looking at. I also would like to try the new Crystal wider FOV lenses but do not want to compromise IQ as it is now.
The AMD 7900XTX for VR is definitely a 9.8 out of 10 factoring in price to performance compared to the overpriced 4090. The Adrenaline software is really good and the card is not bigger than my smallest child like the 4090 is. I hope both Pimax & AMD continue to improve, as I am sure they will.
My first Crystal flickered white streaks intermittently and I had difficulties getting the PC to recognise it. I was worried as the delivery driver had heavily dropped the box at our front door and so I ordered another and it worked pretty quickly connecting to my PC no drama. After a couple of weeks it now has an issue whereby everytime it is first turned on the Right screen will always be a garble of green/yellow static lines. Clicking Restart System in the Piplay software app always fixes it but it cannot be normal so I hope it is software/firmware related and not hardware as I do not wish to go thru Pimax return process again, been there done that with 8KX. Pimax were really good in the process but it is stressful & time consuming. My first Crystal has been sent back and I await my refund at this point.
New Hi Tech hardware is bound to have little issues, the small plastic proximity sensor cover came loose, due to poor quality glue, and before I identified the problem I was having black screen & ipd adjustment issues. Luckily I found the small cover (about 4mm square) as it fell off in my hand and I was able to re-fix it in position. Such small things in Quality Control can cause much time consuming headaches for both customer & manufacturer. I think Pimax are working very hard to get these things right but the .01% minor faults can be costly and do damage to the brand name over time. Fair to say the users with no problems are largely quiet but those encountering issues will be noticed more by prospective buyers, same with almost every product and especially electronics.
I really hope Crystal is hugely successful and I believe it will be as it is a great evolution of the headsets that have come before it and in sim racing or flying it really shines.
Anyway back to some racing in AC which is visualy stunning in Crystal with the new CSP & Pure .222. Thanks and I hope some of my experience can be useful for others contemplating an upgrade. Cheers ![]()
