is anyone using pimax crystal fibre optic cable ive tried it and it will not allow it to used with the light house faceplate ?
Yes been using it for months, no issues.
I don’t use the USB hub or the DP extender box on the headset but plug the tether straight into the headset
jep, using it too. but in the opposite way than xrcdev
plugged into powered usb hub and extender box is mounted again. did try it without but there was no difference for me, since the non appearing 120hz option was a software thing. working without a problem, charging while off works and playtime is around 6-8 hours with one battery. yes, I’ve got plenty of time atm (needed for recovery) and I’m not proud of it lol…
how is the non-working manifesting for you…? doesn’t start up? reboot loop? not recognized at all?
