Hey Everyone - i’m having an issue with lighthouse tracking lately. About 6 months ago, I finally was too frustrated by the 1.0 tracking issues so I upgraded to 4 2.0s. I have them setup in the two corners of my room in front of the direction I face and one in the rear right corner. I also keep one on the window sill in front of me pointing directly at my headset with my thought being, I can’t possibly have an issue with a lighthouse only 3 feet and right in front of my face.
Initially, this setup seemed to work amazingly, but as it always seems with odd things in Pimax world, issues started to crop up. Initially, I had near instantaneous tracking pick up and now it sometimes takes a few minutes to show up. Additionally, while racing in ACC, when I look down and to the left to see the relative/pitscreen/whatever, I will almost always get a screen jump. Sometimes it happens looking in other directions, but most notably looking downwards and left. This is despite having clear line of sight to the entire headset from the top left, front middle, and top right lighthouses.
In the last few days, I’ve done quite a bit of troubleshooting to try and figure this out on my own, and with the help of the lighthouse_console.exe in the pimax runtime folder and some of the sub commands, most notably sensorcheck, I was able to figure out a few things:
A lighthouse 3 feet in front of your face actually sort of sucks compared to the ones that are about 10 feet away and up on the wall.
According to the sensorchecks data, sitting still in my race seat with my hands on the wheel, I get roughly 70 to 90% of the maximum connectivity rating from 3 out of 4 of my lighthouses with only the rear right being fair low. This makes sense at it would barely catch the right right corner unless I turned my head 90 degrees towards it.
Any time I raise either my left hand or right hand to grab the corresponding side of my headset to adjust or lift, about 90% of the time, tracking will start drifting massively with the left hand and maybe get skippy on the right. When comparing this against the sensorcheck command, I lose roughly 90% of the signal with my right hand touching the right corner and roughly 99% with my left hand touching the left side. This is despite almost the entire headset being clearly visible to the lighthouses.
I believe lighthouses communicate over Bluetooth to the headset and as best I can tell, I’m somehow blocking that connection by touching the headset. I suppose I could also be “grounding” an antenna if it is inside the headset and mounted wrong. I was hoping someone else had experience with this or could offer any further suggestions with how to troubleshoot it.
