In order to achieve a more comfortable Pimax 8kx, I made some counterweight boxes for the headstrap. They are designed as an easy to clip on system, no Velcro, tape or screws needed. You can adjust the weight for your personal fit by using more or less AA batteries.
You can download the model from YouMagine:
Hope you enjoy
