Pimax 5k + VR Cover
Yes the VR cover is MUCH TO THIN!
I wear glasses under the Pimax.
With the VR cover what is in the Pimax … it is very bad!
It’s only 14mm thick!
The VR cover should be twice as thick!
Then it would be good!
I have the Pimax VR Cover together with Vivie VR Cover.
That’s fine. The cover is then 28mm!
A good distance for eyeglass wearers!
Otherwise, the Pimax is the best VR glasses that are currently available! I am very pleased!
20190323_235111|666x500
