openXRC modular
As some of you may be aware, goertek ended production of index motion controllers in China last year.
This means the remaining stock is all that is left, and there are currently no indication that the new “Roy” controller will be lighthouse tracked.
Index controllers are now out of stock in several territories, which does not bode well for future lighthouse tracked headset like the new bsb2, somnium vr1, meganex and of course the pimax crystal/super with their lighthouse faceplates!
I’ve had several people contact me recently to see if they could acquire my IP for the modular controller project. It’s not something I ever planned to sell, as it requires lots of pre development work to productivize, as well as some licensing agreements for haptics and input.
The openXRC modular controller was the final design I worked on following project caliper and project modular, both are well documented on skarredghost.
Here are some images showing the testing mule which was built to do ergonomics testing and assembly testing. If you have any questions (and a suitcase full of development$$$ if you want to take on the challenge), I’d be happy to answer questions!
Happy XR! Rob Cole
With the top grip removed showing the “rail frame” construction
“the frame” showing bolt-in tracking head and tracking ring with digital connectors
“brains and power”, with option for steamVR lighthouse or computer vision (and matching tracking components)
Control module with high precision analog mini stick and micro switch input buttons, this mini stick is now available in a hall effect version
And most importantly the controller in the hand :raised_hands:
Open :raised_hand:
And closed :fist:
Haptic hand strap
I thought Shiftall were going to release their flippers at some point.
But goid luck getting your design into production.
Shiftall have two steamVR controllers their flip model and their regular model “GripVR”
Tony Skarredghost tried them at CES but mentioned they felt unbalanced probably the tracking ring
